Seems like 6.2's going out around 19k is the trend these days. Mine went too buddy! New engine should be in this week hopefully. Thank god I didn't put an evil air intake on the truck yet or I probably would've had to deal with the same amount of BS you did. Good thing your trucks up and running.
First Ive heard of a 6.2 breaking, that engine is a beast!! The 2017 Aluminum truck's 6.2 is supposed to gain 25hp and get much better gas mileage, Iam already saving my money for one lol I also hear the 5.3 will be up to 390 hp and a possible Supercharger option. None of this is certain but we all know its coming soon, aluminum that is.. Next Fall could be interesting
You mind sharing that good stuff that you're smoking?
Edited by DanMan_S
I'm scared now. I'll be coming up on 19,000 real soon. :ughdance:
Don't worry at least at 19 they're still under warranty. Unless you're tuned or something.
Thinking about trading in my High Country 5.3 for a Denali 6.2. As long as it's covered under warranty I won't be scared. That Denali has almost 20k on it so I should be good right? Lol
Either it's definitely good or it's about to go :ughdance: damn GM haha.
Bone stock. :thumbs:
You won't be sorry. I've thought about ditching my Sierra for a second 6.2. I've found a new Sierra CCSB SLT in Alabama for $41K. I've traded trucks too often though and I'm afraid of the bath I'll take on trade in. :banghead:
There's two things that hold me back from doing it. First is obviously the financial side. The other is the High Country interior. A lot of people don't like the brown interior, but I absolutely love it. Gives it a rugged look
I absolutely agree. I knew I wanted one of them when I first saw it. I don't think I'll trade my HC anytime soon, the Sierra however I'm not nearly as attached to.
Edited by galliher_nc
Really haven't seen too many posts about 6.2 blowing. Any others having issues? If some are going now I wonder what the full life will be with these. The older ones would go past 300k with proper maintenance.
I wanted to alsopint out that GM officially added a 500 mile oil change interval for the Corvette back in December. A few Auto magazines with long-term cars have had their engines grenade. The consensus seems to be metal debris from the manufacuring process as the culprit.
How convenient! Just get an oil change with every fill-up! (I know, I know, you meant 5000 miles. :-)
No they really are requiring an oil change at 500 miles for C7 Corvettes. It's likely that the oil is picking up contaminants from the manufacturing process or engine break-in. Maybe the old timers that would change the factory oil extremely early had the right idea after all.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
