Power Steering troubles 2001 Suburban
poisonivyvixen
I am at a loss. I was backing up out of a parking lot when I felt a slight pop and my power steering stopped working. We've replaced the PS pump and the Gear box, we also replaced a bad CV Axel. Still no power steering though!? What else could it be?
I am using a mobile app to type this, and do not see any brand or model information for this vehicle.
Follow the power steering hoses to where they end up. If one goes to a cooler up by the rad check to see if it plugged up.
You don't say why both the pump and rack were replaced. Were they actually tested, or were they replaced because someone said "it must be one of those parts, just replace them both to be sure". If that is what happened, you have learned two things, one, there are more than parts that can cause this and second, don't ask that person for car repair diagnosis.
It says '01 'burban in their info, Doug.
Maybe they hooked the hoses up backwards? Don't think that's possible though, but I've never done a rack before, so I can't say for sure. If the supply and return are crossed I'd imagine it would make some horrendous noise too ...
I was using my phone to reply, and there is some app that it came with called Tapatalk. Between that and the 4 inch screen I had a hard time finding anything. Surprised the spelling came out so good.
Power steering lines have different ends, on each line. Lines are usually different sizes since the return line is not under pressure, other than what it needs to push the oil back into the reservoir. Not uncommon to see a simple worm gear clamp holding a return line on. It would not surprise me if GM said they were different to prevent assembly plant errors.
A plugged cooler should also make a noise at least, and should kill the pump eventually as well. I don't know if the OP had the entire rack and pinion replaced, or just the valve assembly. Calling a rack and pinion assy a gear box also does not sound right to me. I just looked and the 1500 series had a rack and pinion system, the 2500 series says rack and pinion, but shows traditional recirculating ball chuck. The OP needs to give more information I think.
At least in the 99-06 1/2 ton pickups, 2WD rigs got rack and pinion, while 4WDs got recirculating ball and nut. I assume it would be the same for the SUVs.
Is it 3/4 ton with Hydroboost ???? The guy has no money left now anyways that's why he's here ,
No Devine intervention here I'm afraid ,
New pump should've fixed it ,
Shop time dude
I think we need more information about what the truck model and the exact problem/symptoms before we can give you any more ideas of where to look. The first thing that jumps to my mind would be check the belt for to ensure tension and check power steering fluid level. The pump may just be low and not working correctly.
I think Rob may have brought up the right idea. Is this truck using Hydro-boost? If they changed the power steering pump, and used the pump for non hydro-boost trucks, maybe the "normal" pump is not big enough to support the Hydro-boost and power steering.
Rob may also be right on the other part of his post. If this truck has hydro-boost, it is likely time to take it to the pros. Again, this is based upon what we both know and don't know about the truck.
It's a conventional system. Yes by the way gear box is correct, there is no rack and pinion. We've flushed the power steering lines several times and added plenty of fluid. It's a 2001 Chevy Suburban 1500 LT 5.3 Vortec. Nothing special just a weird problem.
we replaced all those parts because of the metal shavings floating around in the gear box. we were sure that was the issue.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
