It's getting to be a real issue, I use a fleet fuel card, and I have to enter the mileage, with the display so dim, the odometer is unreadable. Don't know why they changed it for the 2016 model. Never had an issue with it on the 2015, and it appears they are not going to fix it saying it's operating as designed!
On my '14 the DIC in the gauge cluster and the dash screen in the middle will dim whenever the lights are turned on. Not the DRLs, but when ti goes from DRLs to regular headlights for when it gets dark or if you have the windshield wipers on long enough. Never had a problem reading mine in the day or night since day 1.
Edited by SouthernSilveradoGuy85
Apparently it's something new GM is doing, never had this problem with my previous two trucks. My 2016 is exactly the same model and options as my 2015, but only the 2016 is doing it. We have around a hundred and twenty five 2015 models, and don't have this issue with any of them, so I don't know why GM thought it was a problem and changed it into a problem for 2016.
I'm going to ask about it when I take it in for the first oil change. It's so bad in the afternoon you cant read the screen
Mine is that way too, and it's a real problem because the odometer is part of that display, and I have to enter the mileage for my corporate fuel card on almost a daily basis. If I don't do it in the morning, I have to guess, and that upsets the bean counters if I'm off a lot.
  • 2 months later...
I wanted to let you know the dealer contacted the GM tech line and they sent an update for the cluster. After applying the update the dash is much brighter, doesn't appear to fade out, and is noticeably adjusting as the sun sets. As you drive in areas with lots of trees... Hard to explain but as the trees cast a shadow on the dash sensor you can see the dash dim or brighten. I was sitting in traffic, inching forward, in and out of tree shadows watching it work. Which it never did before. It was always one setting and depending on the amount of sunlight it could wash out the dash.
I have the update ID number on the invoice/work order and will post it later
You should be happy after the update is applied.
Edited by GS340
Same here mine did it about a year ago and I did the same thing with the dimer wheel, never done it since.
The issue I was experiencing was not related to the dimmer wheel/adjuster. With the head lights off that adjuster doesn't do anything with regards to adjusting the dash brightness. The problem I was having is in the afternoon getting into the truck the dash LCD would be readable. While driving the dash would slowly dim out to the point you couldn't read anything. Slllloooooooooowwwwwlllllyyyyy fade out over 30 to 45 minutes. The adjuster wheel has nothing to do with it. Turning the headlights on and using the wheel would change the brightness on everything BUT the center LCD. If I turn off the truck and let it sit for while. It would be readable on the next startup and slowly fade again only in the afternoon sunlight. Never at night or early morning. There must have been and issue in the software and the single from the sensor on the dash. It appears the update fixed the issue.
Edited by GS340
  • 4 years later...
I have a 2015 2500 HD and my DIC lights go out all the time in cold weather or warm weather it has 125000. Miles on it the rotator dial has no effect and I use my dimmer switch low and bright no effect what can I do I depend on the DIC for information
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
