Why did you buy your truck?
Atlas
  • Replies 67
I've always had a truck or suv since 1988. I traded up from the colorado I had so I could pull my travel trailer easier. I like sitting up high when driving, not sitting on the ground.
  • 2 months later...
Been driving a truck since I was 20. First was 72 step side Chevy.
Then toyotas
22r
Tacoma 3.4
Tacoma 2tr
Always wanted to get back In a Chevy truck.
They finally got me with the 2015 crew cab.
Purchased for same price as new Tacoma.
All my trucks I've owned turned out to be green.
Always owned trucks, since I was 16. Just recently upgraded to full size trucks though, glad I did. I am one of those guys who HATES having to gently place something down into the trunk of a car or SUV because I may dirty it up. I need the bed to just toss stuff into. Plus, I like being able to view almost everything I want to by laying underneath it, opening the hood, or taking a wheel off. (Had to do a wheel bearing in the sierra this weekend, compared to my mid size trucks, it feels like I have 10x more head room in the wheel well!) We also camp from the bed of my trucks!
It also helps when your GF/wife has the small gas sipper vehicle to offset gas prices.
I had money at the time, and I was dumb - didn't use my head. Could've got by continuing to fix my '94 K1500 wth 266k miles on it, but figured it was time to finally buy new. What a mistake! :banghead: With the amount of money I wasted on the purchase price, repairs, taxes, and insurance, I could've kept my '72 El Camino, and bought 2 more beater trucks in addition to my '94. Live and learn.
I've had a truck since I was 16. They're the only "car" you can get that's not unibody and FWD. These days I tow quite a bit, hotshotting cars within a 300 mile radius for a car dealer. I also work on OPE, so need a truck to haul lawn tractors here for repairs. Also own an ATV - can't carry that in the trunk of a car ...
4WD is almost a necessity where I live, at the top of a long, winding, and steep hill that is always the last to get plowed.
6.2 L... Nuff said
Too bad the Ford crowd isn't going to be able to say that anymore, they are getting hosed. They are being forced into the V6 EcoPoop engines because Ford seems to have gone all in with this 'green movement' nonsense.
The topic over on the F150 forum says
"why switch to GM from Ford"........The response is V8....nuff said!
Sent from my iPhone6
via TapaTalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
