Why did you buy your truck?
Atlas
I have owned a Jeep since I was 15. Did not think it would safely tow a boat when I moved to TN and I wanted to buy a boat. I had a Pontiac G6 as a second vehicle with my jeep. Wanted a boat so I bought my truck. Realized a boat and a truck that was not paid off was rather expensive. Come to realize after moving twice that buying my truck is the best idea I have had for pulling my jeep around the country.
I may eventually get an SUV but I like the option of having an open bed for whatever I may need to haul. My wife can end up getting the SUV later and I'll keep my truck.
  • Replies 67
I had a 2004 Chevy Trailblazer for 11 years. I liked it and it fit my needs, but I have a Quad and got tired of having to haul it around with a trailer. Storing a trailer sucks too. I've always liked Silverados, so after two years of wanting one, I pulled the trigger. I would have waited one more year to save up more for a larger down payment, but last July, I got $8k off MSRP, plus another $1500 off in GM card points. So daddy drove home with a new mother ship, and intends to keep it for about 15 years.
I have a small package and needed to compensate.
Besides that, work around the house, towing, and for the friends who need help moving.
Only talking about the Silverado I have now...
I had a 2006 Honda Civic Coupe which got great gas mileage (38+), but rode really stiff and took the bumps and potholes hard.
I like the ride of the previous Silverado (02) I had and wanted another one that rode as nice and smooth.
Even though I don't care for the 17 - 18 mpg, I like the ride.
I don't use it to haul much of anything, but mostly use it for commuting to work when I don't ride my bike.
  • 3 weeks later...
Recently bought a travel trailer and was towing it with my 07 Classic 15HD, it got horrible mileage and only held 26 gal of gas.
New truck, same 6.0l but much better fuel economy and hold 36 gal. Plus it has better towing capability, so in the future I can get a bigger trailer. And it has a bunch of bells and whistles that the 07 did not.
Got a great deal on my 2006 Dodge Ram 1500 Quad cab with 226000 trading up to a 2014 GMC 2500 HD with 30,700 miles. Could not pass up the deal.
Drove a brand new Chevy truck my dad had on loan from work for a week and I was hooked. At the time I was a teenager and couldn't afford one so I had to wait. But as soon as I could I bought the truck I have now. Wouldn't want to go back to driving a car full time now. I just couldn't do it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
