Clear bra bubble
I just picked up my truck after having a clear bra installed and there are some small bubbles. The installer said it is normal and they will disappear after a week or so...
Does anybody have any experience with this? Will they actually disappear? It is a black truck so I assume everything is more noticeable.
  • Replies 31
I have a few too and waiting on them to go away. Truck is black so i check em everyday waiting for them to disappear. Only been a few days and they said it was normal as well
I have the Llumar paint protection film installed on the front portion of my hood as well as my front bumper. It is normal to have some bubbles, most go away but you may have a few small bubble remaining. Try parking your truck in direct sunlight, the heat should help make those disappear.
Remember, the whole point of the film is to protect your paint and I'd take a few bubbles over a chip in the paint any day.
Yep it's normal. My installer said that after a couple weeks if they don't go away after being in the sun to bring it back in and he uses a needle and sucks the water out.
Had a couple that he did that too and it looks perfect.
While I haven't had this done yet to my truck, that happens tomorrow...I did have the clear bra installed on my 07 vette when new. And there were NO bubbles at all. I am not saying everyone else is wrong - only indicating my experience. Best of luck and I'll update after my install tomorrow. Who knows - maybe I'll have bubbles too :)
I think it also helps to let it sit in the sun after they install it. To help evaporate the bubbles.
Will someone post a picture of this? I don't like the air deflectors and what not but if this item is something like clear window tint designed to cover/protect my paint without really being all that noticeable I am definitely interested.
I have had three installed on dark grey...no bubbles. Let us know if they go away. Dark colors show the most and the owner/manager at Transguard has always done mine himself.
After two weeks all but one bubble went away. Looks like it is working its way to the edge though
Some may not. Trick to fixing them, is to use a small syringe. Fill it with a water and alcohol mix solution. Bend the needle so you can puncture the bubble parellel to the metal. Fill the bubble. Then use a micro fiber cloth and rub progressively smaller circles around the bubble, towards the puncture, to get the solution out. It works great. The film will heal where you puncture it after a day.
There is a big problem of taking photographs of installed clear bra, it's invisible enough that cameras can't capture it. The only possible scenario is when it's installed over paint surface that's worn or "damaged". The clear bra film is very shiny and its surface is like glass coating. When the paint is clean and very good or more, even capturing a seam is a challenge.
See post #10
http://www.gm-trucks.com/forums/topic/173429-2015-hood-protector-deflector/?hl=llumar&do=findComment&comment=1632129
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,266 Guests (See full list)
