No I have spacers in the rear only to get them lined up with the fronts. No rubbing at all anywhere. When I had a 2.5" front level and 1" rear lift I rubbed like crazy with and without the spacers on the front. A lot more with than without
Thanks for the info. I think I'll order a set of 1/2" spacers just to have on hand for the install. I ran 295/55/20s on my 14 and only rubbed SB at full lock and these should be a bit narrower. How are the Pros as far as road noise?
Edited by Bayou-AllTerrain
The pros spec out at 34.29" tall and 12 inches wide. They are noisy but it's a bearable level and a way nicer tone than a straight symmetrical cut m/t. You can tell they put some research in them
I am the type that rarely gets the same size or tread pattern twice in a row to say the least. I am actually torn between another set of these or a set of km2's. 35x13.5 or 37x13.5 is still a toss up as wel.
For anyone that wants to know if you run a 37 with the 8l90 all that is needed is a 3.73 r&p to get the ratios back to what they Are on stock tires with optional 3.42 gears. That's most likely what I'll be doing but let's hope the current ones last long enough to get all the parts ready
I hear ya. I'm on my 3rd set of Toyo AT2. I've had them on my last Tacoma, FJ, and on my '14 All Terrain. Was gonna just get another set for the new truck because they are so damn good but wanted to change it up a bit and go a little more aggressive. Was gonna go with the Toyo MTs but then saw the new Pro and the great reviews. Doesn't hurt that they are $100 a tire cheaper either.
Do you think you could get 50K miles out of them?
I think a person that drives with some sense should be able to get 50k easy.
I however don't fit that driver description.
If I had a 5.3 I think I could lol
Finally pulled the trigger and love that I did 5 inch RC bfg ko2s 285/65r20. Ride is great for a lifted truck, just got to add my steps this week.
I like the setup. What size tire is a 285? Is that 33 inch?
it's the 6inch actually and the 285x65s are 34.6 I believe. I love it, however it's in a million pieces right now. A lady ran a red light 2 weeks ago and just about finished it off, we hit at 30mph, friggin sucks!
4 inch tuff country
Sent from my SM-G920W8 using Tapatalk
Is that the 4" tuff country lift that works with stamped steel control arms? Have a part number of the lift? I am looking at this lift .
My 2015 GMC Sierra Texas Edition with 3.5 RC lift, TLC air bags with 33 inch Federal Couragia M/T on stock rims
Looking pretty sharp my friend.
what size rim?
stock 17" rims and 33 inch tires
nice! been looking for a picture of this. I have stock 17 alloy and want to raise it up 3.5-6 inches and just put bigger 32 or 33 inch tires on my stock rim. Don't wanna pay over 2000 dollars for rims then be afraid to go in woods and get them scuffed up.
this looks great
do you have a before and after picture of front / side of truck
Edited by Sbaer2012
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
