Considering a ProCharger Supercharger
fondupot
  • Replies 52
Yea, I am really leaning hard toward ProCharger. All the other supercharger kits out there are more expensive, and create less power.
What kind of tuning software does ProCharger use? I guess it doesn't matter much, the installer is going to Dyno tune it anyways. So it should be dialed in nicely.
Because right now I use Blackbear tuning. Idk, if I would be able to continue using them.
Yeah, BB will have no trouble unless tuner locks it up, but I don't see that much anymore.
Sent from Off Driller Side
Sounds like a really good deal including install and tuning. I'm weighing supercharger options in the spring. Anyone have a copy of procharger install instructions on a 2014+?
Rob. I have them. I asked pro charger to email them. I can forward them to you. PM me your email address.
Same here, curious what install is like.
Wow, that's going to only take 4-6 hours and that with beer.
I contacted Chuck from HHP down in Houston, the "tuner kit" with the relocated intake, upgraded FMIC, and a custom tune with installation was ~$8k. I thought that was pretty good as he has a 5.3 himself and seems to know them up and down. This is his truck;
I'm on the same boat as Fondupot. I would like to upgrade to a Procharger but it is a steep price to pay. Chuck did say that upgrading headers are pretty much a necessity, so thats another $1,500 going with either ARH or Kooks.
So the tuner kit moves the intake forward towards the 2nd battery tray? Definitely looks better. Idk if I would want to pay 8k tho. I'm still struggling with the 6k tag on the regular kit.
No, to re-route your intake to the battery tray area it's an additional ~$150 to get the intake tube from Procharger. Otherwise the filter will sit in the unit facing the headers.
Oh that's not bad.
What's the difference between the tuner kit and the other one then?
Oh that's not bad.
"The Tuner Kit is identical to the complete system, but omits fuel injectors and computer programmer."
http://www.jdpmotorsports.com/manufacturers/gm-truck-suv/gmc/sierra/2014-2015-sierra/sierra-1500/procharger-ho-intercooled-tuner-kit-2014-2015-chevy-gm-truck-suv-1500-1gv202-sci
I'm not quite sure how good of a tune Procharger will provide for their kit, I'm sure its a relatively safe tune but after driving a year on my BB tune I quite like my TCM programming and would hate to revert it back to stock. I did talk to Chuck about injectors and he said you don't have to upgrade injectors but should if you want to achieve high hp levels or high boost levels.
I think the Tuner kit is the way to go, and I'm not sure if Black Bear would be willing to do a "mail-order" tune for a Procharger or maybe getting a local shop to tune it.
I sent an email to Justin at BB asking if they would be able to tune after the pro charger. My guess is they would be able to. Just waiting for him to get back to me.
Because I agree. I have my BLackbear TCM dialed in nicely. And wouldn't want to lose it.
I'm sure Justin will have no problem tuning your Procharged truck.
He tuned my 6.2 truck with a Whipple!
I'm assuming you caught him at a local tuning event.
It was actually a custom mail tune! I did run the truck on the dyno for some fine tuning though.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
