New tail lights
2SSRS
I would post a pic of the lights but it appears the photos I have on my phone are too big to upload or something. I can try some different ones when I get back home today. I also have a light bar on my front end over the license plate area. ~K.
Good for you, but one more time this is for members that want to step up to the new OEM look, so can we stay on that?
If you read my post I was referring to a company that makes replicas of the ridiculously over priced oem lights.
Glad we have professionals like you on the forum! Wow
Your website has all of the stuff I have been looking for. The fog light hi beam override harness is a bargain, and, unlike the forum mod here, I will still be able to have full control the fog lights.
And I love the idea of disabling the DRL's with your harness, if I convert to HID. I love it that I can run my fogs as DRL's if I choose to.
Can't wait to see the kit you come up with to put '16 headlights in a '14-15. No harm in dreaming, right?
Not to much to ask for and we will work on it next week.
Post all you want.
No i read what you posted and looked at what they had up for sale, if thats what you like go for it, we deal with aftermarket all the time and they don't always work like the OEM, if you like to pm me i can go on, but for this topic, lets stay on point with only doing OEM.
OEM led tails? Sign me up. My anzo's/eagle eyes are ok, but not OEM.
soon.
  • 6 months later...
So its been some time but we have the headlight done as well as the taillights, its all plug and play.
Pics & prices?
Edit: Nevermind, the price tag on these make me not want them just for aesthetics.
I'd easily settle for $250 aftermarket compared to $1300 OEM. $100 for the harness is a good deal though.
Pics & prices?
Yes there a lot, but its OEM, IMO better then aftermarket.
  • 4 months later...
We buy parts from all over, there known as surplus, there pre production units, but there the ones on the trucks, we recived a 2500HD headlight 2 years before the truck came out, its how we make our harnness.
Do you happen to have the website link?
Thanks!
Been looking for a good parts one and stumbled upon this thread
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
