2016 5.3 V8 with 8 Speed loses 1 MPG
  • Replies 49
Is it losing 1mpg vs the 5.3 6sp with 3.42?
Probably not but the 5.3 6 speed with 3.42 wasn't tested by the EPA, only 3.08 was. I would guess that it is even with the 5.3L 6 Speed, MPG wise.
Well that's weird. I would think the 5.3 would see a little bump in mpg with the addition of the 8 speed. Oh well.
Apples to Apples, 5.3 with 3.42 has to have a mpg gain going from 6sp to 8sp.
Well I say they have something wrong as all of the 2wd 2016 seem to have the same millage as the 2015 4WD.
http://www.fueleconomy.gov/feg/Find.do?action=sbs&id=37012&id=34675&id=34677
Unless the new body lost a full mile per gallon on all of the 2016's
I would say the numbers are not right.
The difference in that link is the 8 speed vs. the 6 speed. I would say that it is accurate. As said, the base ratio is 3.08 on the 6 speed but the 8 speed (5.3) is only offered with 3.42. the EPA can only test what they are given and I assume the manufacturers need to supply a vehicle they would actually sell, hence the 3.42 being used with the 8 speed. The question is why didn't GM pair the 3.08 with the 8 speed? Maybe they know something we don't? I think the 1MPG swing would have went the other way with 3.08 gears but at the expense of smooth acceleration/driveablilty.
I think it's because the 8 speed is only available in the upper trims, and those come standard with the 3.42 gears. I don't think you can get the 3.08 in LTZ or SLT for 2015, can you?
2015 GMC
GU4 Rear axle, 3.08 ratio
Base Sierra - Standard and only available on (L83) 5.3L EcoTec3 V8 engine. Not available with (RD3) 20" ultra bright machined aluminum wheels or (NZM) 20" chrome aluminum wheels.
SLE, SLT - Standard and only available on (L83) 5.3L EcoTec3 V8 engine. Not available with (RD3) 20" ultra bright machined aluminum wheels, (NZM) 20" chrome aluminum wheels or 22" LPO wheels.
And since 5.3 is standard on SLT, 3.08 is standard on slt (and 'available' on the others)
I don't get it. Why is a 3.08 gear even offered?
To improve gas mileage on EPA tests with the 5.3L and A6. :chevrolet: The interesting thing is that almost all of the 2015 5.3L LT's in my area had the "optional" 3.42 gears.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
