I'm having a frustrating issue with my 2014 Sierra 1500. I exit the truck, shut the door, and hit the lock button on the remote key fob. All doors (except the driver's door) lock, the lights flash, and the horn chirps for the alarm. The driver's door remains unlocked, yet the security system is armed. When I open the door the horn chirps until I put the key in the ignition. The only way to lock the driver's door is to manually push the lock down before you shut the door or shut the door then lock it with the key from the outside.
Then when I go to unlock the truck, all the doors unlock but the driver's door. I can see the lock moving - it's like it unlocks and then re-locks itself. It is very strange. I have to use the key to unlock the door.
This started last weekend when I borrowed the battery from the key fob to use for another car. While the battery was out of the key fob I used the key to lock and unlock the truck. I started having these issues when I reinstalled the battery into the key fob.
If this is a mechanical/actuator issue I find it a huge coincidence that it picked this exact time to stop working. I'm thinking the remote needs to be reset or something, but I can't find any info on how to do that. I've tried taking the battery back out as well as changing around all the settings related to locking or auto-locking within the vehicle settings.
My warranty ended 48 days ago, so I'm hesitant to take it to the dealer. Any help would be much appreciated. Thanks!
I'm thinking that it needs to be reprogrammed. But all of the instructions I found say for 2014 up, need to take it to the dealer to have it reprogrammed. Up until 2013, there were steps you could do yourself...
What does it do when you use the power lock/unlock button on the drivers door? If that works then it is not an actuator issue.
Hey guys, thanks for the replies.
Good idea to check the other key fob - just did that, and I have the same issues. I guess it's not an issue with the key fob.
If I sit in the truck, with the truck running, and hit the lock or unlock button enough times it will eventually do what I want it to do. The first few times I hit the button nothing happens. Then the next couple times it will move the desired direction, then move immediately back. Then the next couple times it will move the desired direction, then move immediately half-way back. Then after hitting the button a couple more times it will do what I want it to. This also happens sometimes with the remote from outside the vehicle. Very strange.
I've tried it with the "Anti Lockout" feature both on and off, with no difference. Seems like that feature might not be working correctly.
Also, the driver's door does not automatically lock when put in gear or automatically unlock when put into park. The other three doors do.
My next step is to remove/reload the tune. I'll let you know if that fixes the issue.
If anyone else has any ideas, I'm all ears. Thanks.
I agree... It sounds like you are going to need the door lock actuator replaced.
The BCM controls the door functions so it has nothing to do with a tune. It is more than likely a bad door lock actuator.
  • 4 years later...
  • 3 months later...
Having the same problem on my 2014 Silverado. Try the Front passengers door switch  if it works then it is most likely the drivers door lock actuator if not then most likely the BCM. I looked at a wiring diagram the door lock actuators are supplied power When the BCM see's a voltage drop from the door lock switch. To add to the complexity hit the child lock, see if it flashes a code when you do. I find when my locks are operational the child lock is also and when the door locks are not working neither is the child lock function. There is a relay in that circuit it may be worth swapping out...  I took the door panel off and supplied power to the door lock actuators, they worked every time. Good luck, I've learned to deal with it.
  • 7 months later...
  • 6 months later...
My 2014 Silverado is doing the same thing. Only way to lock the driver door is to manually push down the lock. The door switch works for all the other doors as well.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
