Hello from Alberta
jamez74
Thought I would share my truck. It is a 2011 Sierra with the 6.2 engine. It has a BDS lift and a few other things.
76D143D2-149D-4B6B-B313-7C29C42DE887_zps
B314738E-FD20-4A37-B41D-66912481516C_zps
4F7AC452-3382-4BD9-B3CF-816C0672BBE8_zps
6856DFCF-36F2-4D30-BBD7-7A50F4B8CC5C_zps
93AD05EC-0790-41F8-9037-0D34744F076C_zps
Welcome! Purdy truck!
Question... hows the upper dash by the vents? I looked at a few of these before deciding on a new truck, and it seemed as tho all of them had cracks in that area. Just wondering if thats a common issue, or maybe just related to the south with the heat down here
Awesome looking truck! I especially like the color.
There are no cracks that I have seen.
  • 5 months later...
I have had the truck for 5 months or so now. Other than having to have the motor changed a month after I bought it she has been pretty good lol. Glad I had some warranty hehe. I havent done much, it had an aftermarket exhaust and intake already. All I have added was a nav deck and a back-up camera. Here is a picture of her today after doing some spring cleaning on her.
449F1A80-C0D1-4C3B-B540-DA78D16EB917_zps
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
