anyone ever replaced their rear back window with a power slider? if so have you had any issues? I was quoted $1200 but not sure it's worth the money.
If I'm being honest, I'm not sure I'd use it that much, I just like the way it looks compared to the solid window. I know they make manual sliding windows, but I don't want to lose my rear defroster.
I would have liked to have it but dont think its worth 1200 bucks. If I had to replace it anyway for some reason guess Id consider it.
Rear slider is one of the things I wish I really would have gotten.
I had a manual slider on my old truck. Didn't use it as often as I thought I would. I even specifically bought it with it, thinking I'd use it all the time.
Dropping the rear windows is much more effective.
I get turbulance sometimes if I have all 4 down a little, and really bad if it's just the rear 2.
my new 2015 2500 hd has a rear slider with defrost so you don't have to lose it.
is it a manual slider? I was told it had to be power slider to keep defroster?
I wish there was an aftermarket kit that would drop the whole back window (like the Tundra has). That would be worth $1200 to me!
Not sure the little box in the middle is worth that kind of money.
I've been looking at doing this also on my 2011....when you weigh the cost and how much you'll use it, the decision gets a little tougher. EBay has some decent "buys"......but, it's well......EBay. If you do it, please post pics!
Yeah, mine is a power sliding w/defrost. It actually does a good job at eliminating the turbulance when you want to drive with the windows down. The biggest problem is trying to remember to close it at night.
  • Like 4
I have the slider and I used it once to make sure it worked and that was it I forget its there
I use mine all the time, the dogs love it and I also use a vaporizer and on the interstate with the window all the way open you can hardly tell.
I think he was just saying that with the factory slider, you still have defrost.
I guess I'm the only one that didn't want a power slider.. one of the first mods I did after getting my truck.
Edited by Silver ice 6.2
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,249 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
