my windows are open anytime it is nice outside, I would rather have the fresh outside air and feel the breeze. Mine was supposed to have the slider but it was deleted right before it was built at the plant. If I could get it for $1200 I might consider it and would use it anytime the windows are open and down as it really helps with in cab turbulence.
I went out of my way to ensure I got my truck with the power rear slider. I love it and use it almost daily when the weather is nice. I agree with others too saying it helps a lot getting rid of in-cab turbulence with the other windows open. I just open the back up a couple of inches and the air flow is great. Well worth it to me, but again, to each their own.....
I have only had my truck for a couple of months but a power slider was a must for me. When I had the 2003 Ram I sold before I bought the Denali, I routinely put long boards, trim, etc in through the rear window so the ends would fit in the bed. I love being able to do that without climbing in the back seat to open the window.
Love my rear slider and have it open every chance I get. Now just have to get used to remembering to close it which I seem to have a mental block about at times. In Seattle this can be problematic. A couple of weeks ago when I was on a business trip I get a phone call from my roomie saying "It's pouring here. Is your back window supposed to be open?" I was like "What do you think, sunshine?" D'oh! :)
I use mine all the time. With the windows down and the sunroof / slider open, it's pretty close to having a convertible truck. And the kids love it.
So with the Auto down feature on the remote, can we mod this to open as well? Im hoping it would be as easy as a rely like the fog lights. any thoughts?
I use mine quite often because of the turbulence with the regular windows. Now with that said, I would prefer the view of a solid window instead of the tiny slider. Wish the big 3 would copy Toyota and do the full roll down rear like the crew cab Tundra and 4Runner. That would be the best of both worlds. You get the perfect amount of ventilation with no turbulence and unnecessary to roll any other window down with the great rear view.
I wish there was an aftermarket kit that would drop the whole back window (like the Tundra has). That would be worth $1200 to me!
Not sure the little box in the middle is worth that kind of money.
It does look like a Titan back glass. Is that a custom job fitting a Titan window in the GM, or is this a kit that's actually on the market?
I use my slider when backing up a trailer at night since I got 5% tint on the back.
Or if I fart in truck its a great way to get the smell sucked into the back instead of the side windows past my face. :throwup:
If it isn't raining or freezing, my windows are down and the slider is open. I don't care how hot it is. Drives my wife crazy. I love my slider.
Not sure. Found the picture online and saved it.
I was quoted $700 for the slider from a dealer in Maine before I bought the all-terrain.
was this to remove the old window and install a new one? if so that seems like a hell of a deal. on the other hand, it's only a $250-$300 option on the sticker so if that's what your talking about, not such a good deal.
    TopBo
    TopBo
  • Who's Online   2 Members, 0 Anonymous, 1,252 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
