I sent a message to spurshot about this. He said there are no electrical schematics available yet on GM Upfitter for 2015 or 2016 trucks. Since the headlights are so good on the 2016 trucks, I am going to wait for a while to see if someone finds a way to do it. I have found the Intellibeam works just short of perfectly. Really nice feature. Hope GM keeps it.
  • 2 months later...
Yes. That was the first mod I did on my 2013 Sierra. Using a diode to jump #10 to #22. Come on Mod Guys. How do we keep our fog lights on with using Intellibeam?
Mine work great on rural roads . I just leave it in auto and it does a great job. In town it sometimes gets confused with all the lights or it may brightlight a car pulling out from a side road. The auto feature is easily turned on or off..
  • 2 years later...
had no idea the 2016's do this... hhmm.... i drive with my fog's on all the time... so your saying with intellibeam, the fogs must be off......driving with hi beams, the lights dim on oncoming traffic?.. did i understand that right
If you have the Intellibeam option, and it's enabled, they will dim when sensing nearby traffic.
If you have the fogs on, they will always stay on low beam, even if intellibeam would otherwise be turning on the high's.
If you have fogs on, intellibeam treats this as an instruction to leave highs off.
RPO is TQ5    Headlight, IntelliBeam, automatic high beam on/off
for 16/17/18 - Included and only available with (Y86) Enhanced Driver Alert Package.
(for 2019's it is  - Included and only available with (PDJ) Driver Alert Package II.)
  • 4 years later...
Hi! I just purchased a 2014 GM sierra crew cab, and I’m just wondering if just some of them have the intellebeam feature? I drive for a living in the north, and the 2024 suburban I use have them and I just love them, but I can’t seem to find them on my truck? It says it does have auto headlights, but I’m thinking this may not be the same thing, although this is the term some descriptions use for this feature.
I’ve tried flicking the lever bnf twice within 2 secs while on auto, and looking for a button and nothing. I’m thinking using a flashlight to see if there is an a symbol on my dashboard, but thought I would ask just the same.
Also, does anyone know if this option can be installed on your vehicle?
Thanks so much for any help you may be able to give me! Cheers!
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
