I will give this a shot and report back with my findings as well. I typically get 15-18mpg so if there is a noticeable swing i will let you know. It's only gas guys, give it a shot and report back.
It makes absolutely no sense that you would get BETTER mpg with Tow/Haul - it keeps your RPMs higher and delays up-shifts. By definition, you're burning more gas. Unless something has changed, there is no change to the engine tuning, it only changes shifting.
Thats what I was thinking but people are saying they feather the gas to keep it in v4.... not really sure having to feather the gas every acceleration would be worth it. Im excited to see some numbers lol
anyone found any actual downside to this yet? don't care about MPG but meaning extra wear and tear or confusing the ECU by always being in tow haul?
also what do you guys mean by M6 and M5, you put it in manual and actual shift with the button while driving?
There shouldn't be any downside that I can think of. Even the mileage hit I would expect to be minimal - 0.5 to 1.0 mpg.
If you put it in manual mode and M5 it turns off the AFM so you don't go into V4 mode.
I find the V4 mode shudders, almost as if I'm lugging the motor, when driving in town. I don't like it so drive in M5 most of the time in the city.
Glad i am not the only one who notices the V4 shudders. Must be an "issue" on all of them.
Hm the only think I notice really is my truck has a super hard time shifting. I have a 3" lift on it and I didn't drop the drive shaft. Do you think that could be the culprit?
I see how it could help mileage in town but on the freeway I shift out of tow haul. Otherwise it doesn't shift in to overdrive.
Overdrive works in tow mode on my 2015 5.3L 6spd....
I had blackbear modify my tow haul to make it sport. It was awesome!
I'd like to know the details on this. So they modified your tow haul mode how? Is it still optimized for towing?
How is your tune for regular drive then?
My tune is in progress with Blackbear so id like to consider this.
Ok ladies and gentleman,
I decided to run 3 tests to get some actual numbers. Take them for what you will and know that I drive like a grandma and worked with what I have.
Specs:
- 2015 Chevy Silverado LTZ 4x4
- 3" leveling lift
- Airdam still on
- RetraxOne Tonneau cover
- Stock 20" rims and tires
- DeeZee step bars
- Running in 2WD mode
Distance:
- 10 miles exact
Terrain:
- City stop and go with occasional long stretch all flat land
Weather:
- Cloudy and 64 degrees F
Camarillo, CA
Assessment with Tow/Haul ON:
- While driving with this on for the 10 mile distance I was able to achieve 15.2mpg during which time I noticed that the RPMs consistently stayed high. Shift points seem to be smoother but at the same time the truck was staying in the same gear for longer before shifting. The hard shifting that normally ensues with my truck went away. The truck DEFINITELY has more sport to it. From a dead stop there is no delay and the throttle is more responsive and more aggressive.
Assessment with Tow/Haul OFF:
- While driving with this on for the 10 mile distance I was able to achieve 19.7mpg during which time I noted normal shift points. The shifting is definitely more rough but the rpms constantly stayed down keeping the truck in a higher gear. There is definite difference between having Tow/Haul engaged and not having it engaged when it comes to throttle responsiveness.
Selective Tow/Haul Engagement:
- As I was reading through the comments I noted some people saying that the truck remains in gears longer and stays in V4 mode longer. I got to thinking about that and decided to try one more experiment with selectively engaging the Tow/Haul button when in v4 mode to keep the truck there longer. This actually yielded some surprising results. Driving the 10 mile stretch while engaging the button each time my truck entered v4 mode yielded 21.7mpg! Granted, engaging it each time and disengaging it when v8 came on was kind of a pain, but an argument can be made for long distance driving where v4 engages more often and for longer periods. On the freeway my truck stays in v4 most of the time at 70mph but kicks into v8 when a slight hill comes up. If the truck could be forced to stay into v4 during these transitions to small hills, there might be quite a significant increase in mpg.
This is just a rough test and I actually plan on doing a freeway test today if I end up going back out. The test will be a 20 mile approx test but I will have more exact numbers when I do it. Let me know if anyone else attempts this or tries this out on the freeway.
The truck:
wait so you are saying I can put it in M5 and drive around and it will shift up through the gears normally but stay out of V4? It won't just stay in 5th? or do you need to shift your way up to 5th with the buttons?
Set it and forget it. Shift to M, click up to 5 and it will shift like an automatic until you shift out of M.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
