Electrical Grimlins or Something Else?
amc019
Had a few issues come up with my truck over the past couple weeks and I am struggling to figure out what the root of the problem may be, and the dealer seems to share similar difficulties.
All of this started out with a Check Engine Light that appeared randomly after it struggled to start up once, and when I say struggle, it just turned over more times than it usually takes to fire up. OnStar stated that the code was reading low voltage in one of the sensors on the fuel system, she was not entirely descriptive. Took it to the guy that tuned my truck with an HP Tuners tune, and he found a P0641 trouble code, showing an issue with the 5V Reference Voltage for sensors within the motor. The truck was also throwing a code (cant remember which) for faulty or incorrect barometric pressure readings within the intake manifold. After awhile, the trucks condition worsened, where every time I needed to apply a heavy amount of throttle from a stop or extremely slow start, the truck would cut out, almost like it was starved for fuel or hit the rev limiter, and kind of hiccup until it got rolling. It does not do this once the truck is moving at a fairly quick speed, like passing cars on the highway it doesn't miss a beat.
I had my tune removed from the truck and set back at stock, and took the truck to my local dealer. They decided that the truck needed a new ECM and replaced it under warranty. Great. Engine light off for 4 days and came back on after I applied heavy throttle from a stop to get around another car where the truck hiccuped like it had before. The following weekend, I was towing my side by side on an 18ft car hauler for the last weekend of duck season, and the truck really struggled off the line while under load, I had to ease it very carefully from a stop to prevent it from hiccuping and cutting out, not giving it much throttle at all.
So yesterday I brought the truck back to the same dealer, and they decided it was the Mass Airflow Sensor, replaced it this morning and by the time I got home I managed to get the CEL to come back on and do the same thing it had been doing before.
The only other issue with the truck occurs when I go to fill up the fuel tank, something happens where the pump almost always thinks its full, and cuts the pump off. I am assuming it is a bad vent solenoid, or the charcoal canister, but that issue has taken a back seat to my current issue. It has been like that long before any other problems occurred, so I am assuming that the issues are unrelated. (unsure of technical term for the solenoid or if they even use charcoal canisters on these trucks anymore) Other than that, the only codes popping up are for my HID headlights, the truck thinks they're burnt out or faulty, but these codes alone do not cause the CEL to light up.
However, it is possible in my mind that something is occurring in the gas tank that is not allowing it to vent properly, and under heavy loads where more throttle is applied and large volumes of fuel are needed, maybe the tank is starving the motor? Which causes it to cut out momentarily. Kind of like pouring gas out of can without the vent opened up, just tries to suck the sides of the jug in and doesn't allow good flow. I am just throwing shit at the wall and hoping it sticks at this point.
I take the truck back in tomorrow to see what the dealer can figure out. I hope someone can give me some advice as to what the issue could be, as I am getting annoyed with taking so many trips to the dealer. Thanks in advance.
It seems that your truck is suffering from "We flushed the quality control down the toilet" gremlin.
Systematically check all your electrical connectors to various sensors. Do this after disconnecting the battery negative terminal cable. I would unplug each connector, check that it is free of corrosion and plug it back.
You could be right, I had a 2011 Duramax before this, and had many issues with it as well. I really thought I would be doing myself a favor by going with a 1/2 ton this time around to avoid issues like these, but apparently not. I am a GM guy at heart, this is my 4th GM truck and I am only 22, but it seems like I have the worst luck with them.
Just make sure they don't find these as the cause:
2015 GMC Sierra All-Terrain Crew Cab
6.2 & 8 Speed - 2.5" CCM Level - 305/55/R20 MTZ - AirAid CAI - Magnaflow-HP Tuners
If they do...bye bye powertrain warranty...
They haven't said anything about the tune, as I had it cleared and set back to stock before taking it to the dealer. Some say they are traceable, some say they aren't, who knows. The tech that has been working on my truck mentioned that his supervisor questioned the intake, but even the tech told me that he has one on his truck as well and not to worry about it. Either way, the dealer would have to prove that the intake single handedly caused the malfunction in order to void the entire warranty. I think if they wanted to void it they would have by now, its been in their hands 4 times so far.
Also, I've had the intake on the truck for almost 6 months, if that were the culprit I believe the MAFS would be the only thing it could affect, and even a once they installed brand new one it didnt fix my issues.
At the same time, I have never heard anyone mention that a custom tune caused a problem with the electrical system on their truck. The guy that did mine builds racing corvettes, trans am's, and everything GM related, so I am confident in his abilities as a tuner.
here is a thought. have them check your battery. if the battery is going bad, it can send a low voltage signal that will "throw codes". some can be read, some can not. just had my battery replaced because of the low voltage signal, I was getting "service brake assist" and "service stabiltrak" with out any codes to show why. good luck!
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
