Oil smells like gas
Hey all, is it normal for the dipstick to smell like gasoline? I changed my oil at 2500 miles to M1 and I'm now at 3300 miles. I went to check my oil and noticed it smelled of gas...
As a side note, is it normal for the exhaust to smell like gasoline on startup?
I also use Mobil 1. The 0W-20. Just changed it last week, and as it was draining I swore it smelled like gas. Just so happened that oil went to Blackstone for analysis. Not a trace of gas in the oil. Oil had a little over 6,000 miles on it.
Interesting! I'm sending my oil to Blackstone as well.
I feel a little better about it now but just incase the test comes back showing a high volume of gasoline, is there anything I can do to fix that?
If there is, I wouldn't know. Any of this relevant, couldn't tell you that either.
I don't baby it, but I don't drive it like an idiot either. I don't let it idle more than a minute at startup. I've never disabled AFM. My 80 miles a day are 50/50 stop and go, and turnpike speeds. Fairly certain my rings are well seated from breakin.
I have had Blackstone run a few UOA's on my Sierra now. None of them have showed any measurable fuel in the sample. I haven't really noticed any fuel smells when changing the oil either. Most of my driving is highway which gives the oil a chance to warm up and burn off any potential fuel. I've always heard that vehicles that do mostly short tripping without any longer highway drives are more susceptible to fuel dilution.
gone_fishing, thanks for posting your oil report. That's some good info and a good baseline for me. Would you recommend I send my current oil with a little over 1k miles on it to Blackstone or my old factory oil with 2k on it?
Factory fill UOA usually show a lot of metals due to brake in. Silicon levels are usually really high due to silicone sealers. I wouldn't bother since it really doesn't tell you much. The 2nd oil change will usually be a little closer to normal but still high due to break in. If you have 1k on your current oil I would just wait till you change it if you want to send a sample in. Besides my UOAs, I have looked at few other Ecotec3 UOAs over at BITOG and they all look pretty good after 7k miles (no fuel dilution or anything series popping up).
  • 3 years later...
Sorry to drag up an old post, but I just sent a sample out to blackstone. 2014 5.3L Sierra 1500 L83 @ 97K miles. My question is, when the results come back, is ANY gasoline considered a problem? Or at what percentage are we saying it is too high that we need to start looking for a fuel system cause? Thanks, Chris.
If there is fuel smell in your oil on these trucks, check it after it’s been sitting and see if it’s higher on the dip stick than it’s supposed to. The high pressure fuel pump leaks fuel into the oil when they go out. It sits sight underneath the intake manifold. If that’s the case you will need to have the HP fuel pump replaced.
^^^This^^^
There is a known issue with the HP fuel pump leaking into the engine oil.
There is a really great DIY video on youtube on replacing the pump, not that hard.
Its by The Sundae Drive channel.
Here's an old oil analysis I had done when my oil smelled strongly of fuel.  Seems like winter time has high fuel dilution because my truck doesn't warm up well and summer is fine.  I have started to ignore the OLM, as long as I'm not approaching 0% and change my oil in Nov. and March (Only do about 7k miles/year).  Try to get the fuel out of there before I start towing in the spring.  Both samples I have sent in after winter have high fuel.  Sample at end of summer and 5k miles is perfect.
This is an interesting topic..... I’ve smelled small traces of fuel in my oil as well during OCI’s, does it mean I should have my fuel pump checked for possible contamination??
Sent from Above
    B07
    B07
  • Who's Online   0 Members, 1 Anonymous, 839 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
