G80 Gear Lube - Eaton phone call today
FL335i
Figured I'd share. The net is full of discussion on what type of oil the G80 rear ends need. Syn vs Dino, LS vs non LS. Well I finally got around to calling Eaton's diff tech support. Very helpful guy. He clearly explained the G80 is not supposed to have LS friction modifiers. It does have clutches that operate the locker. The 75w-90 Syn is fine. So M1, Valvoline etc at the parts stores all have LS friction modifiers. I'm actually looking at buying this http://www.phillips66lubricants.com/documents/conoco/industrial_oils/FOB%20Triton%20Synthetic%20Gear%20Lube%20TDSw%20778906.pdf
I can buy it for about $150/Pail. I can do my '14's front and rear diffs and I have my 89 K5 Jimmy I'm restoring which has two straight axles. Much cheaper than the store 1L bottles. Plus I cannot find 75/90 Syn gear oil locally w/out LS additives.
EDIT: The above link is the 80-40 Triton oil. I'm going to buy a pail of the 75w-90 FE gear oil. Correct Data sheet link: http://www.phillips66lubricants.com/documents/conoco/industrial_oils/FOB%20Triton%20Syngear%20FE%20TDSw%20828151.pdf
Interesting that the clutches are not supposed to have friction modifiers. Amzoil Severe Gear is approved for the G80 and front axle on our trucks. Phillips/Conoco also makes very high quality products. I would have no issue using their GL5 full synthetic product.
Gm has only had a bulletin out for the better part of 2 decades about proper oil with the old gov bomb. It's funny that in its 43 years of production even most dealers are clueless of what to use for oil in it lol.
Sent from my SM-G900W8 using Tapatalk
I have to say, I've never been a fan of the G80 but it seems they've improved them in recent years. In the old days it was a "one wheel peel" for quite a while until the G80 would "kick in" locking violently. With the 2014, it feels much more like a standard LSD--never letting one wheel spin too much before you can feel the other getting torque. It seems to work well enough I'm not in as big a hurry to get rid of it.
They had a bad rep for durability, especially in smaller axles, but these for the 9.5/9.76" are all new so I think that's largely unknown for these particular units. It has been more than two years now and there doesn't seem to be a bunch of posts from people who have broken their diffs.
Every now and then mine refuses to lock up right away and make a bunch of ugly grinding noises. I'd get it checked out at the dealer but secretly I'm hoping it gets bad enough to motivate me to replace it and regear. I have my eyes on a Detroit Tuetrac.
It's probably my fault. I've beat on it fairly hard the last couple years.
That's because the average owner and mechanic don't know the difference between a G80 limited slip differential and an G80 mechanical locking differential. That plus the fact that GM uses the same G80 rpo code for both, which adds to the confusion. Limited slip differentials (aka Posi) are normally installed in performance cars. The only truck to ever get one (known as RPO G86) is the Quadrasteer, QS was a Dana axle. A locker was inappropriate for the QS.
Here is the SPID label from my 2009 CTS, note G80, Limited Slip Differential because no car gets a locker.
da8939d6-7af3-4838-a7ee-5954e36d4698_zps
2012 GMC pu, note G80
#PIP4054D: Eaton Locking Differential Chatter Shudder Noise On Turns - (Jul 19, 2010)
Subject: Eaton Locking Differential Chatter Shudder Noise on Turns
Models: 2004-2007 Buick Rainier
2000-2011 Cadillac Escalade, ESV, EXT
2002-2011 Chevrolet Avalanche
2004-2011 Chevrolet Colorado
2003-2009 Chevrolet Express
2000-2011 Chevrolet Suburban, Tahoe
2000-2007 Chevrolet Silverado Classic
2007-2011 Chevrolet Silverado
2002-2009 Chevrolet Trailblazer
2004-2011 GMC Canyon
2002-2009 GMC Envoy
2000-2011 GMC Yukon, Yukon Denali, Yukon XL
2000-2007 GMC Sierra Classic
2007-2011 GMC Sierra
2003-2011 GMC Savana
Equipped With a Locking Rear Differential RPO G80
This PI was superseded to update model years. Please discard PIP4054C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Customers may comment on a chatter or shudder from the rear axle on vehicles equipped with an Eaton locking differential. This condition would be noticed in parking lot maneuvers, turning, or during locking differential engagement and may be more noticeable when the differential is hot. Locking differential clutch chatter may be causing this concern.
Notice: This does not apply to vehicles equipped with RPO QS4 (Quadrasteer) which is part of option package NYS. Quadrasteer vehicles use Dana axles and have a different fluid requirement.
Notice: This PI does not apply to vehicles equipped with a RPO G86 limited slip differential.
Recommendation/Instructions:
If differential clutch chatter is encountered in a vehicle equipped with an Eaton locking differential, flush, drain and refill the differential with new synthetic fluid, use the fluid part number listed in SI for the vehicle currently being worked on. If the condition returns, replace the rear differential clutch plates and refill the differential with new synthetic fluid, use the fluid part number listed in SI for the vehicle currently being worked on. Refer to eSI for clutch plate replacement and set up procedures.
Notice: Eaton locking differentials used in 10.5 rear axles are equipped with steel clutch plates. It is a design characteristic of these steel clutch plates to exhibit more clutch chatter than other models.
Important: Installing any friction modifier causes the clutch pack in the locking differential to slip and miss engagement. A fluid flush can often remove debris that is a contributor to clutch chatter. Adding friction modifier additive can cause a loss of locking differential functionality.
Notice: On Quadrasteer equipped vehicles, simply flush the rear axle and refill with the fluid listed in SI document 793720 under the steerable application.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
The reason I know and have this information stems back to the mid 90's when I had an incident with a Chevy dealer who insisted they needed to add a limited slip additive (and change me a confiscatory fee) to my truck G80 rear axle when I had them R & R the gear lube with my own preferred brand. The mechanic and SM insisted I did not know what I was talking about so I was out to prove them wrong. Long story short, I did and they had to eat crow and flush out my rear axle on my truck. Never been back to that dealer since and never will.
I don't like stuff that shock loads to engage.... and has a normal state of being open.... not to mention i want my rear end locked above 25 mph..... My 9.76 version operates like a gov lock from 1973 and bangs itself to lock.... It probably will never break based on physical size but it's the only thing in the truck I actually want to put in a metal bin. However being I have the 9.76" setup, and how pathetically slow the aftermarket is going about things even for the 9.5", I don't forsee the aftermarket ever making carriers for it so I doubt I will own the truck long enough to change it..
But back to the thread yes just standard synthetic gear oil with no clutch additives is all it needs.
Not sure how much the G80 has changed over the years since mine is an older model. So far it still works great and engages like it supposed to when out in the wet grass, or farm fields. 160k miles using AMSOIL's Severe Gear 75w-90 fluid in front and rear. I switched it out when I purchased the truck new and after putting about a thousand miles on it.
Maybe I'm on borrowed time, who knows. Love the truck and so far the only thing other than regular maintenance that I have had to fix is the alternator going out.
I know all that thanks lol. G86 was also used in the 9.5" 14 bolt in the Trailblazer SS as well because gm chose to give them a limited slip instead of a gov lock. There may be some 10.5" 14 bolts out there that are G86 coded from the 80's and 90s but I don't remember anymore.
I don't care if the average owner can't figure it out... the average owner can't handle basic maintenance. However the service departments should and yet in recent times I have still had one mention you are supposed to use additive in the gov lock... I just shook my head and left lol. On the flip side back in 2014 when I had a CTS V I had a parts monkey have a freak out on me that no vehicles built in 2010 by GM needed limited slip additive. I just told him he was an idiot and either get me the additive or I would go elsewhere because it wasn't for a gov lock in a truck.. he just turned red and got the bottles. Peoples haves the dumbs!
^Exactly 1994 Vmax. I use a paint marker on the tires to indicate the proper tire rotation PER THE OWNERS MANUAL DIAGRAM for my wife's 2015 Enclave. Every single time I take it in, or she does, the service writers give us a rash of crap about not being able to change direction of tires, GM changed the rotation now. On and on and on. I just politely smile and ask them for the updated GM literature, TSB, Owner's manual revision etc and I'll be happy to oblige and agree with their back to front, front to back half-arse rotation pattern. They can never produce anything. Not to mention the Michelin website rotation pattern agrees with GM's owner's manual diagram. Just another example of them bamboozling average people who don't know or don't paint mark the tires so they know for certain it's done right. When my silverado was new and I was using the free oil changes I did the same thing, paint marked them and notified the writer. 4hrs later for an oil change and rotation on a Saturday, it comes out with the wrong rotation pattern. SMFH. DIY FTW.
^ I don't buy that BS. When a diff and gears break-in, there are lot of particles. It's "lube for life" b/c the average life of a car is probably 6yrs/100k. Life is also subjective. Who's life? What life? It's more BS from the mentality to save oil and save money and decrease their maintenance costs to fleet buyers. I had a wheel seal fail at 16k. the dealer replaced the wheel seal and re-filled the diff with non-GM fluid. It's not purple... looks like regular gear lube. I know before I took the truck in for the repair the "purple" stuff looked black as night. Since the wheel seal fluid flush repair the lube has stayed clear. Breaking in diffs requires a flush. Period.
From GM's perspective, the life of the vehicle is the length of the powertrain warranty. In my opinion it's not a coincidence that a transmission/T-case fluid change isn't required until nearly 100k miles in their maintenance schedule.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
