G80 Gear Lube - Eaton phone call today
FL335i
Figured . Plus I cannot find 75/90 Syn gear oil locally w/out LS additives.
Redline 75/90 NS should fit the bill. I've used it in 1 tons towing heavy loads and it reduced the diff temp significantly.
Don't get the Redline 75/90 without the NS designation as it does contain a friction modifier.
^ My 5 gallon pail of Conoco Phillips 75/90 Syn will do just fine and comes out much cheaper than most bottle oils. Plus it's got Mack, Eaton, Road ranger, on and on of all kinds of approvals. Stuff we'd never see on a bottle of X brand at Autozone. But yes, good advise Last C5, the NS designation is critical. I've used redline GL-4 80W IIRC in 80's supra manual transmissions. Best oil in the world for those things.
  • 4 years later...
On 2/13/2016 at 5:48 PM, redwngr said:
Probably why the new diff fluid is 'lube for life' and does not require changing.
Right.  Not for the life of the vehicle.  And certainly not the owner.  Maybe right for the life of GM until the next bankruptcy, though.
The million dollar question:  is using off the shelf Mobil 1 or valvoline (that already contain a small amount of additive) going to ruin your G80? It seems tons of people have used the Mobil 1 or valvoline.
The answer is no.  I've used both in my G80 trucks and never had any issues.  Currently running Valvoline Full Synthetic 75W90 both front and rear in my 18 and it doesn't have any effect.  The only thing you really need to worry about is if you have the Posi style rear end and using the correct amount of limited slip additive.  If you don't put in enough of the limited slip additive, the clutches will not engage properly.  The amount of limited slip additive in both Valvoline and Mobil 1 is very small and no where near enough for a Posi style rear end.  I always had to buy the additive for my 94 Camaro when it still had the 10 bolt in it and add it to the gear oil or the Posi would not work properly.
I thought this would work for limited slip rear ends.
This for G80. Very little additive I believe.
75W-140 Full Synthetic Gear Oil, 1 Quart
Used this in my truck without issues.
Synthetic 75W-90 GL-5 Gear Oil, 1 Quart
so those of you who have owned 4x4's for hundreds of thousands of miles, for a new silverado when would you change the front and rear diffs and transfercase? When would you change the trans fluid?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
