Yes please do keep us updated ben.doyle.37. My vehicle is still having this problem and I've oretty much just given up on fixing it at this point and just reset it every time it happens.
On 1/23/2023 at 4:06 PM, ben.doyle.37 said:
Hey guys,
dealing with the same issues. Replaced the thermostat and temp sensor, reset computer and still having the same issue. My truck is a 2018 Chevy Silverado 1500 5.3. I’ve also replaced the radiator before this. My brother is a mechanic, he’s going to put the computer on it this afternoon and see if we can find anything as to the reasoning behind this. I’ll keep y’all updated and any advice would be greatly appreciated.
Were you able to come up with anything on this Ben?
  • 10 months later...
Having the same problem. '14 silverado 5.3 . Changed sensor and thermostat.  Lost some fluid while changing . Didn't think it was much. Drove around to see if anything changed. Fans still on high, gauge flat lined. Checked fluid and realized res was pretty much empty. Filled and repeated the drive. No change. Upper rad hose was cold and felt empty. Did not check with scanner or pull cables off battery. So.....would the low coolant cause this issue to continue? Could there be a bubble stuck at the thermostat? Any help would be great
Try removing the Neg Battery cable for a few minutes to reset the system.  This should kill the fans and the temp gauge should read normal afterwards.
Has anyone tried changing the relay and/or fuse for the fan? I ask because I'm having the same problems and changed out both the thermostat and sensor. Fan kept running after thermostat, but stopped working at all before I got chance to replace sensor. I figured the relay and/or fuse blew from fan constantly running, but when I checked the fuse box...neither was even there! Confused as to how they could run without them. Hoping my fan didn't go out with no relay, because it was obviously running without one.
I have a 2016 silverado with a 5.3 I changed the temp sensor and the thermostat and the fans are still stuck on high coolant is full what should I try next.
Hello, running into this issue now at about 150k miles. Long road trip to the Guadalupe mountains, about one entire fuel tank worth of distance cruising down the highway.
Turned truck off that night, no problems, camped near the truck, no noises or leaks that I could tell
Headed to the national park visitor center the next morning and when I turned it off the radiator fan kept running. Looked under the hood and didn’t really see anything. Radiator overflow tank had fluid. Suspecting the sensor or the thermostat. The fan turns off eventually. Later that day after hiking the Guadalupe peak I noticed the temp stays at 160 degrees pegged low. I stop at a rest stop not too far away and the same issue, fan turns on, eventually turns off.
I got back on the road running the heater full blast, watching oil pressure like a hawk, ambient temperatures were 75F or so high with 50F lows, so not anything extreme. Get to a hotel as I wanted a shower pretty bad at that point. The fans stop again, impossible for them to stop that fast if it were really over heating
Next morning after the hotel stay, everything works, temps normal and no radiator fan issue
I was ready to replace the thermostat and sensor, but if it works now I won’t bother. I assume the long drive stressed a relay or sensor and normal shorter drives fixed it
Edited by awright2009
  • 7 months later...
I had a similar thing happen this morning. The fans went to high speed, and the temp gauge went to zero.
I've also had an issue with the wipers moving to the intermittent position by themselves.
And a probably unrelated event: My hood popped open to the safety catch on the freeway! It was fully closed when I started the trip. Yikes!
Anyway, I inspected the temp sensor but decided a power reset was in order.
Problem(s) have ceased.
Methinks that some of the PCM code musta been written by Microsoft!
Now to figure out the hood issue.
2015 Silverado LT.
  • 11 months later...
On 11/2/2019 at 11:45 AM, DoyleR said:
I just replaced the coolant temp sensor on my 2014 Silverado and the engine fan is still running wide open and the temp gauge is still not working. My mechanic will likely have to figure this one out.
Hardwire a ground to your ext sensor ground wire. It fixed my issue exactly like yours.tan wire may pass visual inspection but may still be bad or going bad
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
