My 2014 Silverado had the same code P050D and I took it to the dealership and they replaced 2 defective fuel injectors. That was on 24 April 2018 and yesterday (7 May 2018) the code comes back????? I am taking the truck back to the dealership this afternoon for another diagnostic. I am sure it is fuel injectors. The technician suggested that I replace them all but my extended warranty wouldn't do it and I can understand that. If this is going to be happening every couple of weeks we have a serious problem! I purchased the truck new in 2015 and have 59,611 miles on it and this is the first major issue so far.
Update of code P050D. I had another defective fuel injector:fume: The extended warranty company authorized Chevy to replace the remaining 6 injectors. I was very pleased because I couldn't see myself coming in every couple of months to replace 1 or 2 injectors. Now the warranty is on GM for 12 months. Lets hope this is the last fuel injector issue I have with this truck.
Well, the fuel injector issue was just the beginning of my problems with my GMC. The horrible projector headlights was next. Followed by losing the condenser and compressor for my A/C. The driver's side seat back kept falling off, even within minutes of a new replacement! Then, to boot, my mileage dropped 6 mpg between city and highway with no reason (or at least the dealer couldn't find a reason). All this with only 37k miles! I had had enough of this truck and went back to a Ram five months ago and have been much happier. GM has lost another customer.
Edited by elzie
I received a call Saturday from the service department stating that fuel injectors were back ordered and they didn't know how long before they would be available. WTF!!! Who is running the supply chain at GM!! It makes you wonder if these injectors are failing at such a rate they can't keep up. This is unsatisfactory!! I am paying for a truck I can't use and to make matters worse I need my truck for my upcoming vacation and the dealership doesn't know if they can provide me with a truck.
After almost 4 years of ownership and almost 60K miles I was happy with my Chevy. I am fortunate I have the extended warranty, it has paid for itself after only two service visits. I will be researching other truck options once I get the truck back. I am concerned that the fuel injector failures will come back later down the road if GM doesn't change the design. I could be doing this again at 80K. The Dodge Ram is looking better every day:-(
I had this issue on my 15 6.2 at 24k miles.  It was at the dealer for 2 weeks due to backorder of injectors.  They replaced 3 under warranty, so far so good.
I got my truck back this morning after they replaced 6 more fuel injectors. I took them 2 weeks to get my truck fixed. So far all injectors have been replaced by the dealership. I am really considering getting another truck due to the reliability of these injectors. What will happen a year or two down the road?? I like the truck but don't want this headache later.
I purchased fuel this morning at a Chevron station in Houston, TX.  Immediately upon restart after fueling I had an engine light on the dash.  Before driving home tomorrow (700+ miles), I had Autozone run the code.  It is P050D.  29,546 miles on a 2017
i would have them reset the code and see what happens, if it comes back it is more than likely a bad injector. I just got my 16 back with the 6.2l last month for the same code. 1 week later and 1 new injector and I was all good to go. Truck only had 22k miles on it at the time.
  • 5 months later...
On 2018-04-22 at 7:46 PM, Brianx220 said:
Im guessing mine is having the same problem.. P050D is popping up 87K miles old. this is frustrating because it was just misfiring on cylinder 4 a month ago with code P0300 (Random/Multiple cylinder misfire) of course took it in to the dealer i bought the truck from had it serviced and now this.. 2 codes P219 and P050D.. all in the same week that it was just serviced for P050D.. took it back to the dealer only for them to of course deny everything as the all do i imagine.. but then said they will look at it for me but it will cost me the diagnostic fee.. why would i pay that again if i already paid for the misfire issue... im loosing fait in GM to be honest. My Dad's old Tundra at 120K miles is still runing properly with all original parts yet mine is becoming a money hole... please let me know if there is any way to fix this myself.
I know this is an old post, but I'm getting exact same errors. What was the solution to this? Injectors?
Your dad should consider himself lucky because the Tundra has several very common issues that costs far more than replacing a couple injectors. Just a basic "Air Injection Pump" for a Tundra typically costs $750-1000. The pump itself at one time was costing around $400, wasnt covered outside of the bumper to bumper warranty, and they failed often some guys have had to replace them 2 or 3 times (cold weather regions). Starters on 2nd gens are extremely common problems, usually fail at 60-80k miles, and it's usually an 8 hour job to change it. The rear axles are a major problem on these trucks. The Hino axles they use leave a lot to be desired in terms of durability and quality control. Many earlier 2nd gen Tundras had wheel bearing failures in the first 40k miles in some model years. Even now there are a surprising number of pinion bearing failures and even problems with the carrier being made of steel that was too soft, requiring a lot of money to totally rebuild. Their 2-piece driveshaft design also sucks.
As mentioned previously, it can be as simple as a bad tank of gas. If you've run through a couple tanks using different stations then the next common solve is replacing your injectors. I'd recommend doing them all at once since, as others have said, the problem can pop back up with the injectors you didn't replace. If that doesn't do it, you can have a more serious issue where coolant is leaking into a cylinder (or multiple) and causing a hard cold start up because it has to burn the coolant off the piston. Coolant can also be leaking externally from a head bolt. If either is the case, the solve for that is replacing the driver and/or passenger side head. Apparently the original manufacturer that cast the heads for our trucks didn't always do a great job and pinhole leaks can occur allowing coolant to go where it shouldn't. PIP5498 gives more detail (https://www.corvetteactioncenter.com/tech/knowledgebase/print-1364.html). Don't let this freak you out though, MAJORITY of the fixes for P050D have been getting good gas back in the tank or replacing injectors. It's rare to have the coolant leak. If you're still under warranty I would take it in ASAP to get it on record that you're trying to fix the issue. That way if you go over a warranty, they will still cover any costs with fixing it.
I've been hearing different answers from different people. Do you know if injectors are  covered under power train warranty?
I should add I'm also getting the P0300 on cylinder 8 as well...
Edited by 09chevsilveradoltz
Adding more
Yup, power train covers them. One other cheap attempt you can try is throw a bottle of Chevron Techron fuel treatment in your gas tank. It usually doesn't fix the issue, but in some cases the treatment can clean your injectors enough to not throw any more codes. Worth a shot for a few bucks, but I'd take it to the dealer ASAP to start the warranty process.
I am having the same problem with my 2016 it started about 4 months ago with only 47k miles now; after replacing spark plugs, o2 sensors and going crazy... dealer told me I have a bad injector # 7 however the recommend to replace all 8 injectors and while we are at it replace the fuel lines at a "discounted" price of only $1800.  ( it stinks to be asked to pay that much for truck you are still making payments on)
The service adviser pulled all the lame excuses; he even told me I have been putting some bad gas in there, I told him that it was the same gas that goes into the rest of the cars in my household and none of the other cars have any issues. (a Ford and a Honda that are running like champs with more miles)
Gordon and Partners is a law firm that has a office in the same building where I work; they have filed class action law suet in the past against car makers before for problems such as this one... as son as get around to it I will let you all know if we have a case and see if you would like to participate.
On 8/5/2018 at 1:07 AM, Katie Hobson said:
Come On Man... You are not sorry if you don't have a solution. Telling us that you will gladly hand us names of dealers that make your company more money isn't help, it's advertising. This Seems like a Huge ongoing problem. I have seen a lot of people having this same issue and it really sucks. Mine shut off on my this morning and when I started it up the engine light came on and sure enough P050D code. So now I don't know if it is going to catch fire and blow up or what. I put a can of seafoam in it, hoping that would take care of it, but nope. Not yet! So now I am guessing I will have to take it somewhere to get told they will have to do so much more than they really will and hand over my first born. Ugh... For a truck with so little miles there has been far too many problems.
I feel you pain my truck now has 47k miles it has been acting up for about 4 months... new spark plug, new O2 sensors, just about every brand of fuel injector cleaner, seafoam in every form possible. Dealer wants $1800 to fix the truck I'm still making payments on!
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
    • There was a recall on the tailgate in general for opening on its own. Mine has a cap on it and it won’t let the tailgate open.   My tailgate has two holes in the top of the tailgate. I filled them in with silicone sealant.
