I noticed that the plastic pieces on the back of the cabs between the bed and cab are peeling at the top. These are rub strips that keep the rubber gasket from touching the paint. Has anyone had the dealer fix this? If so, how did they fix it? Remove the bed?
I just went outside to look and it looked like one corner of the driver side piece peeled off but it's not enough to worry about. I wouldn't worry about it too much unless it peels off so much that the piece on the cab is touching the bed.
Mine are too, I have no idea what they are for?
My guess would be that it's to stop the cab and bed from hitting or just touching when the frame twist which shouldn't be a big problem on these trucks since they're fully boxed and not a C-frame like they used to use.
Okay, I went out and looked at mine and see what you are talking about. Mine are fine but it is in the garage most of the time. I am pretty sure those are there for either aerodynamics or to prevent dust from flying around. They are to flimsy to protect anything. If mine was peeling I would just take them off.
They are there to "close" the gap between the cab and frame both visually and aerodynamically.
My driver side one is peeling at the top, noticed it a few weeks after I purchased the truck. Just one of those things that I said, meh that sucks, but not worth screwing with dealership.
Double sided tape was not the way to go with these. I suspect it will be one of those things where most of the K2 trucks will have them falling off when they are 5 years old or older. I again would just pull them off.
Mine were peeling off. During a visit for an oil change brought it up to my service adviser she had them replaced under warrantee. All they did was pulled the old ones off cleaned the contact area very well and put new ones on they come with sticky tape on them new. Not an issue since they fixed it.
  • 4 years later...
Mine are doing this also on both sides. I bought the truck brand new in Feb. 2019...I mean I could understand if it was 10 years old, but it looks awful...Especially for a $40,000 truck...like why are we taping plastic strips to the back of the cab? Anyone have luck just removing them?
  • 1 year later...
Mine are peeling as well. Both in the driver and passenger side. I just got a quote from the dealer $900 to replace them because they need to remove the bed in order to do so. I’m just buying the replacement plastic pieces from the dealer for $75 and trying to replace them myself without removing the bed
  • Haha 1
Welcome to the site.
Part number?
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
