275/55/20 vs 285/55/20 tires
The 275 is a factory size tire, the 285 is going to be wider and taller. 285 is tread width and the 55 means 55 percent of 285mm is the sidewall height
I run a Pro Comp 295/55R20 (they call it a 33x12.5R20 but its slightly smaller) I have a slight rub on my gatorback flap at full lock when the suspension travels. I can fix it with a tie back but I rarely rub it so i havent bothered yet. My buddy runs a 305/55R20 BFG AT's with molded mud flaps and he doesn't rub at all. It all depends on your wheel offset. Both our stock 20's have a +26 and leaves me no where near my control arm or sway bar like everyone else says. You will have no issue running either of your selected tires. You will notice a decrease in power and fuel economy with a wider taller tire. My E load Pro Comps are 35lbs heavier per tire than the passenger car rated Wrangler SRA's it came with. My bud and I are both running R.L. 2 1/4" front and 3" blocks in the rear. You wont need either to clear a 285. Here is a link I used to get a rough idea: https://tiresize.com/comparison/. Note that aggressive sidewalls and raised lettering will make a tire wider than its advertised width, all tires from different brands with have differences in actual geometry. Link to determine your factory wheel specs: http://www.wheel-size.com/size/chevrolet/silverado-1500/2016/
I've got the 2.5" Ready Lift and run 275/65-20 BFG KO2's. No issues.
Be sure to look at the ACTUAL TIRE SIZE, each brand differes in actual size. I use tireracks website to see actual specs for each tire.
285-55-20 all the way!
+1
I've had both. They are pretty close. The 285's are 10mm wider and about 0.4" taller. Not really a substantial increase over stock.
I had 285's when I had Cooper tires. But I traded the coopers for BFG's and went back to OEM 275's. I can't really tell the difference.
Is it possible to run these size wheels and tires without a leveling kit ?
Yes, you can fit 285/55/20 without any suspension mods. And, in my opinion, they'll look better than the 275's.
  • 1 month later...
Going from stock 275's to a 285 or 295 all terrain won't make much difference. Running something like a 305 mud tire will be noticeable.
I'm running 295/55/R20's with 0 Offset rims. No rubbing. 2.5" Level though
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
