Anyone running Putco Fender Trim
  • 1 month later...
Edges of wheel wells are getting chipped badly so I bought the Putco stainless steel fender trim.
Install easy,fit pretty good except one had to be manipulated a bit.
They look good and will protect the edges .
Overall pretty good product for the price.
i bought the black stainless , either they sent me the wrong ones or they are not designed right. i could not get the front one to sit tight against the truck, 200 bucks of s&&t.
do you have any pics?
I just ordered a set off amazon for $116, If they fit good I am hoping to sand them and apply a textured bed coating finish to match my go rhino rb10 steps.
  • 1 year later...
Are you guys concerned about water and dirt getting under that trim and rusting out the well lining? How is it holding up so far? I have bought the stainless steel trim but not installed it after I examined the design and noted that it is hollow under the trim and just a moisture and gunk trap.
If the paint is already chipped, then you probably will have rust issues, but if it's not, then you probably won't.  For example, my truck came with the plastic flares from GM, and when I took them off to replace the fender, there was no sign of rust underneath them, just runs in the paint.  There was some rust in other spots, like where the battery box is.  Same with the fender I replaced it with, from an '01 Sierra (also had the same fender flare).
If you do have paint chips, you might want to at least scuff them and then put a couple of coats of clear over them before putting the trim on (just scuffing/clearing where the trim will cover what you've done)...
On 2016-05-16 at 9:52 AM, pcruis1 said:
I've lifted my truck (2014 silverado) and added some larger tires. I've been debating for quite a while now on fender flares. Is anyone running the Putco Fender Trim? If so, do you like it? Here's a link: http://www.autotrucktoys.com/chevy_silverado/Putco-Chevy-Silverado-Black-Platinum-Fender-Trim-PRD39365.aspx
I have the black platinum fender trim...pics are in this album:
SASK_RT's RCSB
I find that the fit could have been a little better but I think anything is better than leaving the edge exposed to rocks.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
