When looking for 2016 headlights to possibly purchase to install on my 2015, I am seeing many headlights advertised as "GMC SIERRA 1500 DENALI 2016 16 LH LED OEM HEADLIGHT LAMP ASSEMBLY 1424" or similar that have a chrome housing on the inside instead of black. I think i like them but i can't find a single pic on the internet with these exact lights in them. Does anyone know what model these actually come in? Or am I missing something?
I noticed that also. I've only seen the chrome bezel lights in one truck and I'm fairly certain it wasn't a denail. It was that Hunter green looking color truck.
I don't think the turn signals work correctly with the harness either. The harness is required for sle models that didn't have dedicated drl
This is correct. Last I heard from Ofer was it may be possible to shut the DRL off with a time controlled relay. He was supposed to test and let me know. That was a month ago and I just emailed him to check for updates.
  • 1 month later...
Hi everyone we, at Gen5DIY, have come across 3, brand new in the box, sets of the 2016 GMC HD Headlights. These are not the "C" style, but are the 14/15 SLT style with HID's installed from GM. Price includes harness and shipping in the continental USA. $949.99
http://www.gen5diy.com/DIY-Retrofit-Kits76/Headlights8/GMC-SLT-LED-HEADLIGHTS/
Well, after reading this thread, I took the plunge and bought a set of headlights for my Denali. I understand the repin and purchase of the connectors, but it's unclear wheather or not if I actually need the in-line resistors.
Just for the blinkers to prevent hyper flash. Same for the taillights if you do those. You will also need a capacitor on the headlight wires.
Are the harnesses to make the 2016 lights work with a 2014 SLT available? If so I'm interested in purchasing the harness. Also, will the harness work with the LED headlights our only the HID ones? Also, has any progress been made in getting the DRL to go out when the turn signal is on?
Sent from my Nexus 6P using Tapatalk
Edited by BringTheRain403
One more night pic that should help.
is that just low beams or low beams and fog lights?
Also, would it be possible to see a night picture comparing the low beams and high beams against the wall?
Also, anyone that had HID's in the stock housings that have gone to this setup. How do they compare? The headlights are literally the thing I hate the most about my 2014...
Correct, low beams only, no fog lights. The 16 SLT lights are simply amazing.
Yes, there is a harness to make the 2016 SLT lights work in a 2014 SLT. Yes the SLT lights are the LED lights. I haven't made any progress with the DRL shutting off.
Would something like this not work for what we are trying to accomplish?
I feel like the issue with this might be when you turn your headlights on the DRL go to half power and don't turn off with the turn signal.
I bought the retrofitsource switchback drivers which would be pretty much whats in that video but they never worked.
So does this conversion work or does it work with issues? Was thinking of doing this mod but for nearly 2 grand when it's all said and done they would need to work like factory for me to make the plunge.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
