Thx! Anyone installing these with the resisters should know that the resisters get pretty hot. Hot enough to burn you and melt plastic so make sure you attach it somewhere on metal and away from anything that could melt...
Sent from my Nexus 6P using Tapatalk
One thing to note is they only produce heat when the turn signal or flashers are on. But yes don't mount them to plastic. Use BringTheRain's location of the radiator core support next to the head light.
So how was the night time drive? :driving:
Edited by zmnypit
Much better. I noticed the beam is a lot wider and reached further out than my original lights with HID's in them. I also didn't notice shadows in the beam like my other lights...
After a closer inspection, I feel like my cutoff line isn't quite as "crisp" or "straight" as some of the pictures I've seen. I'll take some pictures if my phone will show it tonight. The line seems somewhat jagged. I realize here are steps in the lines and it won't be a straight line from side to side. In between the steps it seems like there's some light scatter. Maybe I'm just paranoid and trying to find a reason I got the used set for cheap still, maybe not. Overall performance seems excellent, no complaints there.
Sent from my kayak
Yea I agree my cutoff line isn't as crisp as I was expecting but it's still far better than the old lights.
Sent from my kayak
Did you adjust them where both sides line up with each other? If done correctly you will have one low line and one high line. If not adjusted then you're going to see 4 lines.
Same here. Did you adjust? For OEM lights these have some of the better lines I've seen. Granted this is the first set of LED headlights I've messed with. We used to have an Audi before my wife's Yukon and it had the cleanest lines. It was HID though.
Edited by zmnypit
I haven't adjusted any yet, I'll need to go down a touch for the level I have on I'd say. Is it the top screw toward the middle you use to adjust the height? I remember reading about adjusting them a year or two ago but I can't remember.
Sent from my kayak
Yea I adjusted mine so the cutoff lines are level as at the same height as my old ones. The cutoff lines aren't bad but certainly not on the level of a FRX projector with HID's
Went to adjust and looked through the top hole, I'm not seeing the white adjustment screw where the 2015 was, where is it on the 2016 lights?
Sent from my kayak
Edited by SkeeterMcSkeet
You should ALWAYS level your lights anytime you change them out.
For you guys trying to level... Pull right up close (6" or as close as you can get) to a flat wall on a level surface... mark your cutoff w/ some tape or marker.. usea tape measure from ground up to make sure your cutoff is at the exact same height as your projector... ... Use your tape measure and back up exactly 25'. Your cutoff should be a few inches lower (2-4" or so I forget) than the marks you made previous, if not adjust as needed.
What it all boils down to is that your cutoff should never be any higher than the height of an average cars sideview mirrors... whatever the heck that is. Above method gets ya real close.
It's been a while but correct me if I'm wrong that the driver side will always be a touch lower than passenger due to projector housing?
Edited by kj3475
Was interested in doing this mod but after pricing with my source at local dealer forget it. $1,800 plus tax too steep in my book for headlight upgrade. I know could look for used sets on eBay but don't want to take a chance with scratched lenses and broke tabs.
That's why the majority aren't buying new. Its not really a chance when the sellers have it described or pics shown. One of mine did have some scuffs on the lens but I wet sanded and buffed it and like new again. Of course they were no where near $1800 tho.
Yup, 1500grit should get any imperfections.. compound, and you've got brand new looking lenses. I bit mine w/ compound every few months to stay crystal clear.
Broken tabs aren't the worst thing in the world either. Alot of sellers will have the piece of tab that you can plastic weld back one and function correctly.
Theres a few sets out there now that are steals...
Few more harness made tonight and dropping off at the post office in the morning. I have 2 sets left for anyone that's interested that I haven't PM'd or texted.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
