Better late than never.
Finally got pictures taken of my truck. Got it may 2015 has about 24000 miles on it now. Love the truck get lots of compliments. I came from an 11 f150 lariat which I enjoyed that truck as well. Went with GMC strictly because the interior appealed to me more than the 15 f150.
Only problems I've had with the truck were some paint adhesion problems localized to only the front lower bumper which Miller GMC did a great job getting that fixed. Also had the heated seats replaced since they stopped working at around 18000 miles.
The accessories I've added.
HID kit in headlights
Rigid fog lights
Rigid back lights mounted under rear bumper
LED box lights mounted on a switch mounted in the box
GM trailer mirrors
Duratrac tires
MVI Android auto
Husky floor liners
2015 GMC Denali 6.5 box 6.2/8 speed transmission
post-142564-146498787203_thumb.jpgpost-142564-146498788079_thumb.jpgpost-142564-14649878895_thumb.jpgpost-142564-146498789691_thumb.jpgpost-142564-146498790584_thumb.jpgpost-142564-146498791224_thumb.jpgpost-142564-146498791991_thumb.jpgpost-142564-146498792548_thumb.jpgpost-142564-146498793055_thumb.jpgpost-142564-146498793457_thumb.jpg
Sent from my XT1585 using Tapatalk
Love that DIC! Great looking truck for sure.
Another day in paradise[emoji631]
Sharp GMC! What size Duratracs? I plan to go with the Duratracs next year. Only have 12,000 Miles on my '14.
They are just the stock size or close to it.
How do you like the LED fog lights? Send me a link where you got them, I'd like to do that next. Thank you!
I think they're awesome. The have a very wide pattern it lights up the ditches on both sides of the road. I have them wired in to turn on with the brights and also with the fog light button on the dash.
http://safety.rigidindustries.com/led-lighting/50481
I like the low profile lights you used for the reverse lights. You have a link for them?
Always glad to see the blue trim on the doors and anywhere else you have decided to place it [emoji41]
Nice! I like the blue and CC standard box!
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
