7 hours ago, MapleBud said:
How did you grease it?  Did you put grease in the boot?
I used a grease gun with a flexible hose and needle tip.  The grease in the gun is made by mercury marine for lubing various points on boat outdrives and bearings.  It’s tacky and should tolerate heat and water.  The boot seems to have a collar inside and there is play between the collar and boot and collar and column.  I just pumped a bunch in all the “gaps” and wiped the excess off the column.
Do you have a pic of what you’ve done?
4 hours ago, NE18 said:
With the information from this thread, I went to the dealer and told them about the pip5570 and had the service performed in mid-December. Sound went away initially but now its back. Truck is going back in next week.
So I got mine done dec 27, and I can faintly hear it coming back. It’s starting to piss me off
I'm thinking about rigging up a piece of sound proof material and gluing it around steering column and hole on the inside. Hell, I may even just duct tape it.
Sent from my SM-G950U using Tapatalk
I thought I was going crazy but I started noticing it again this past weekend. Not as bad as it was before but it's there. Let us know how this goes.
Ok so I thought the sound was coming back but I’ve noticed it’s more of a wind sound. It seems my truck is missing weather strip off the drivers door. ca1e83f13df8b178ed09fac90ab21ad8.jpgea7318cbfbb84f4868b6d4a62219de9b.jpg
Picked up the truck. The sound was confirmed. They reinstalled the steering column seal and ensured it was fully seated. The sound is now gone. We’ll see how long it’ll last.
If you open the door you will see the weatherstrip on the inside. It's just pinched.
1 hour ago, Blk17Machinep said:
2 dealers and not one can find this 5570 bulletin...
Sorry to hear that. Maybe a call to Chevy corporate is necessary to help you and inform the dealers of the bulletin.
I printed and brought them the bulletin and they had no issues changing it
It was missing, holes were exposed, replaced without issue
34 minutes ago, Blk17Machinep said:
One dealer said “I’m gonna be honest here with you sir I’m not finding anything 5570” I read it aloud to him and still nothing.
maybe I’ll call Cadillac and gmc.
I FUGGGING HATE GM
Wow. If I was in your situation I’d probably do the same. Grease it but I’d trade it in as soon as it made financial sense. The tick was annoying especially when towing and I couldn’t put up with it.
Wow. Unbelievable that it was missed.
Thanks for the grease trick it ACTUALLY worked for me!  I grabbed a socket and tightened everything around the boot where it meets the firewall.  Surprisingly everything was not tight.  Next I did my best to get stp hi temp grease inside the boot from under the hood.  I then greased the exposed steering shaft hole from inside the truck.  So after doing this combination I took it for a 30 min test drive (hills, highway, side streets) and I couldnt hear anything.  I’m shocked and I hope it holds up.  i think the combination of what I did  contributed to less sound entering the cab.  2018 silverado crew cab Z71
A loud metallic ticking noise while driving under load while the engine in V4 mode was happening to my 2014 5.3. Dealer found it was the seal between exhaust manifold to down pipe.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
