Whats Your AC Vent Temperature??
Out of curiosity I keep a cooking thermometer in the vent of my 2014 Silverado. I keep my temperature setting at 72 to 74 degrees. My vent temp usually runs around 50 degrees. What kind of temp are you guys seeing?
Usually 43.5-45. I have a digital thermometer. Thats in 95F plus south Texas heat. Good AC, much better than my 2009 Avalanche.
Cabin (mixed) temp is not supply air temp. You keep the thermostat at your house at X*F (70-75*F?) in the summer but the registers in your house are blowing air at a much cooler temp if everything's working right.
Yes? I'm certainly not a vehicle HVAC expert.
Idling no rec it's 73 turned full blast. At speed it will drop to 64. With rec turned on its 51 and at speed mid 40's. Taking it in this week because that seems crazy to me. 73 without rec turned on? Anybody else?
I am also no expert on HVAC, but I believe a condenser in a vehicle can only cool air by about 20 degrees (or so). If its 105 outside, it will be blowing 85 through the vents (roughly). Now when you run it on recirculate and the cabin is cooled down, then the air it blows out gets much cooler.
I'm glad that in my neck of the woods, 85 is a hot day. My AC sure cools the truck down fast when driving. My truck has the best AC of any vehicle I have ever owned before.
It was reading 102*F on the way home from Orange Beach, AL yesterday. Interstate but large runs of much lower/slower speeds because of traffic (Mobile Bay tunnel lead up for instance).
Didn't have a read on the supply temp but did have recirc on and even when the sun was in my lap, I was very comfortable. 25-33% fan speed est.
I was watching it today. Outside temp in the mid to upper 90's.
It is the automatic version. I have the temp set to "LO" and operate the fan and recirc manually.
Hot interior after sitting in the sun:
Idle, recirc off: ~70F
Idle recirc on: ~60F
Cool interior after A/C has been running for a while:
Highway travel, recirc on: 45F
Highway travel, recirc off: 50F
Idle, recirc on, ~50F
Idle, recirc off: ~55F
I'm not impressed. It is not as good as my last two Silverado's (2009 and 2010) which would run about 10F cooler. It does put out a lot of air though, so it's really not too bad, just not as good. I'm usually in shorts, so I'm ok, but if I was in a business suit, I would be sweating. I suspect the A/C is designed for maximum fuel economy just like everything else on the truck. It is always in recirc mode if left on "automatic" control. I hate recirc because it is so loud.
The compressor is noisy too. Makes a whirring sound. I wonder how long it will last.
I'm gonna have to check mine. Even on the 90+ muggy days keeping it at 70 on auto is actually comfortable and it cools pretty fast.
I also have tints all the way around which imo makes a fair impact to how hard the AC has to work.
Haha I have limo ceramic all the way around and even then non rec isn't an option. I just can't imagine that it blowing mid 70's at idle on a hot day is what it's designed to do.
  • 1 month later...
Did you ever take your truck in to have the ac checked, I live in the central Valley 100+ summers and I don't think the ac is up to snuff even when it's 85 out . My girl friends jag turns into an ice box in the same temps seems like the truck struggles to stay cool
I think most vehicles are still using the R134A if I am not mistaken? Looking at a Pressure/Temperature chart for R134A Typically an automotive type system will run in mid to high 30's PSI pressure on the low side so the evaporator refrigerant temp translates to the low 40's this usually translates to a low to mid 50f air temp at the vent exit into the vehicle if the system is working correctly. A common problem in the past has been the mixing door on automotive systems your HVAC case contains both a heat and a AC coil and the mixing door controls the temp. If it is NOT moving and closing and sealing completely that could be your problem. To test I would find a place where it is as quiet as possible and run normally for a while and then stroke the system from heat to cool a few times. Listen closely for any clicks or strange noises, the door actuator gears are simply plastic and can strip easily you might help your dealership pinpoint the problem quickly plus you might find that the door resets itself after moving it a few times and your PROBLEM goes away.......................................................................
  • 1 year later...
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
