Sc-livestock Posted July 2, 2016 Posted July 2, 2016 I have a 2005, 1500 5.3 v8. It over heated on me so i replaced the thermostat and new fluids. Now it heats up to just to the left of 210 on the interstate and holds there but will heat up to almost the 3/4 mark when driving around town and stopping and going. Is this normal or should i replace the thermostat again.
intheburbs Posted July 2, 2016 Posted July 2, 2016 Could be lots of things. Water pump could be starting to go. The fins of the radiators could be clogged with crap - leaves, bugs, etc. Fan clutch could be going out.
Sc-livestock Posted July 2, 2016 Author Posted July 2, 2016 After I drive around in town and it's just about to the 3/4 mark, it'll slowly go back to normal temp ( just to the left of 210) when I get on the interstate. I check the fins, there a quiet a few bugs and dirt in there, I live out in the country. I'll clean those out for a start, then maybe new water pump?
Daryl LBZ Posted July 2, 2016 Posted July 2, 2016 No clutch fan on an 05, it has E-Fans. What brand of thermostat did you buy? Also make sure your fans are working.
Sc-livestock Posted July 2, 2016 Author Posted July 2, 2016 I just bought a thermostat at NAPA. Any recommendations on where I should get one?
Gurrzt Posted July 2, 2016 Posted July 2, 2016 Could be lots of things. Water pump could be starting to go. The fins of the radiators could be clogged with crap - leaves, bugs, etc. Fan clutch could be going out. I agree with this, you should consider a radiator flush, at the least.
Sc-livestock Posted July 8, 2016 Author Posted July 8, 2016 Flushed the radiator and refilled with new coolant. Still stays just to the left of 210 but will go over a few marks when driving in town. Doesn't get to the 3/4 mark like before but still won't stay under 210 when in town. When I get back on the highway it will slowly go back to normal temp. Should I replace the thermostat again?
Chris Posted July 8, 2016 Posted July 8, 2016 Flushed the radiator and refilled with new coolant. Still stays just to the left of 210 but will go over a few marks when driving in town. Doesn't get to the 3/4 mark like before but still won't stay under 210 when in town. When I get back on the highway it will slowly go back to normal temp. Should I replace the thermostat again? GM's coolant should be changed ebvery 5 years or 100k. I change mine every 3 years
diyer2 Posted July 8, 2016 Posted July 8, 2016 When ever I read a post like this I always think, " it over heated for a reason" Did you maintain the cooling system? If you had it wouldn't have over heated unless a part failed. IMO If you flushed the radiator and it helped cool temps in town when less air is going through the radiator I believe the radiator has some plugged up passages. This would be the case if it wasn't maintained properly.
Sc-livestock Posted July 9, 2016 Author Posted July 9, 2016 Passages inside the radiator or should I unhook and check all the hoses for something clogging them?
Chris Posted July 9, 2016 Posted July 9, 2016 Passages inside the radiator or should I unhook and check all the hoses for something clogging them? The channels inside the radiator where coolant flows across the core, also a good cleaning of the outside with some Simple Green and a good hose would help.
Sc-livestock Posted July 9, 2016 Author Posted July 9, 2016 What is simple green? I take it I could get it at napa? Thanks everyone for the help and suggestions.
Duelin Posted July 9, 2016 Posted July 9, 2016 Another thing that you should check is what is the temp when the fans come on? I use a scan tool and an infrared thermometer for that. If the fans are coming on late then the ECT sensor might be sending a false signal to the computer.
txab Posted July 9, 2016 Posted July 9, 2016 Another thing that you should check is what is the temp when the fans come on? I use a scan tool and an infrared thermometer for that. If the fans are coming on late then the ECT sensor might be sending a false signal to the computer. +1 Make sure your e-fans are working properly. They have a high and low speed. Simple green is available at grocery store ect.......
