7 hours ago, texasaggies16 said:
Looks much better! did the 14-15 to 16-18 swap on my Sierra, all LEDS FTW!
Nice, and thank you! Yeah, I was looking at a 15 Sierra and said if I were to buy it, I would do the same thing. You made a wise choice my friend lol.
Edited by DBrach
  • 3 months later...
12 hours ago, oswaldo unger said:
what all did you have to change on the front end to get the 2016 look, i aswell own a 2015 and love the 2016 models.
The list is in this thread. If you have trouble after reading this thread, shoot me a PM.
  • 4 months later...
Super interested in doing the opposite for this, I have a 2017 and prefer the 2014-2015 front end.  Anyone in the pacific northwest and want to trade?
I was able to almost break even for my swap out. I was able to sell all of my old parts for about the same cost is what I bought the new ones for. It took me almost a year to find and buy the new parts for the upgrade at the cost I was willing to pay. When I say new, I mean the 2016 version. Out-of-pocket I think I was $800 and that was for painting my front and rear bumper to match.
In regards to doing the reverse conversion, I believe it would work just the same way but my initial thought and only concern would be how to retrofit a plug-and-play wiring harness to go from the 2016 LED headlights to the downgraded halogen headlights. But that is probably a gen5diy question or a PGamboa.
Great info, thanks! is it only the grille and complete headlight assemblies?  Or do you also need brackets and radiator support, etc...?
Edited by Zakk
Zakk and I have spoken and will likely be swapping front ends.  I will be swapping from a 2015 Silverado LT and I think his is a 2017 with LT headlights, not LTZ and no fogs.  I will be looking for the 16+ bumper with fogs to complete the conversion.
I do have a question for those who have done this conversion. The wiring kit that is available from Gen5DIY I have seen available for this 15 to 16+ LT conversion has a description that states that the parking light function does not function correctly.  Specifically, the headlights stay on, rather than go off.  I would like to make sure all the functions work correctly.  Is there a harness that allows all the factory functions to work correctly?
[mention=159655]pgamboa[/mention] from harnessdr.com is actually working in this particular issue, I have the gen5 harness which works properly but it doesn’t function as factory set up.
I will be getting Phil’s harness as soon as completed and install on my 16 conversion.
Nice!  Hopefully it comes out soon.
I have a 2014 Chevy silverado and converted the front end to the 2016 front end.  My trouble is, how do i connect the headlight to the harness because the light are totally different.  do anyone have a diagram that can help me connect the headlight up correctly to the old existing harness.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
