Skid Plates?
You can buy the 2 front skid plates seperate and save a little money. I found the part numbers and went to the dealer and ordered them.
The part #s for the skids are:
Front from behind bumper to first crossmember. 23135960
Rear from first to second crossmembers under axle/rack. 23135959
Do you know if these would have to be modified as per CamCamero1991's post below?
They will work, however on my 2016 I had to enlarge the rear holes on the front plate, 2 sets of plates did not bolt up. (front only)
Which part number(s) did you buy that you had to modify? The individual plates or the 3-piece kit?
The picture on GM's site is of the plastic shield but you get the aluminum ones. I just got mine last week and had them sprayed in Line-X.
Did you have to modify your plates at all to fit your 2016, as per CamCamaro1991 mentioned?
  • Replies 55
My holes were slightly off. I had seen his comment prior to my install so I expected some variance. I also knew it would be a tighter fit due to the bed liner spray. I used a drill to shave a little off and fit all bolts very loosely and worked my way around a little at the time. That front plate would not have fit out of the box without a little widening of the holes. Sorry I didn't mention that earlier. Also one reason I didn't try to order the plates separately is I wasn't sure they would include the proper bolts although you could use the ones from the plastic shield and cross members.
Sent from my Nexus 5X using Tapatalk
So if I order the separate 2 plates. I will be fine with the bolts coming off the plastic piece (2 bigger bolts/4 smaller) then the 2 bolts from driver side diff support and 2 bolts in passenger side diff support. No extras are needed?
You'll need 8 large bolts for the new front plates so I guess you would be short 2...
It's not really any cheaper to get them separate because the shipping almost doubles
For the extra 6$ you'll get he transfer skid and the bolts for it all so that's not a bad investment over just the 2 plates.
  • 2 months later...
Outstanding!!! I either missed it or there isn't a year model in these posts. Will these fit a 2014 1500? Also, anyone had any luck on a rear dif metal plate?
  • 2 months later...
That looks great and should be super durable. I've already sent an email to my local dealership to get a quote.
I paid like $120 to spray mine.
Sent from my Pixel XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/topic/192614-tenscourts-2016-ltzz71-ccsb-4wd-silverado/
My bed liner dealer charged $100 to spray my step bars and brackets. I'll get a price for the plates.
AND, does the hole in the second plate give access to the oil filter? Read where another guy covered it because it didn't.
    nolankd
    nolankd
  • Who's Online   3 Members, 0 Anonymous, 201 Guests (See full list)
