Switched from Toyota to GMC Sierra after 30 Years
Bill Zizzi
I have owned nothing but Toyota trucks and SUV's for the past 30 years, when it came time for a truck I traded my 2011 4R for a 2014 CPO Sierra 1500 CC Std bed 4X4 Z71 with 5.3L and 3.42 rear.
So far I am enjoying the truck, I hear Toyota owners bashing the American made trucks but after talking to true GMC and Chevy truck owners who have nothing to say but good things about their trucks
I decided to give one a try. To be honest my last few Toyota's were far from trouble free, Had transmission, torque converter, manifolds, fuel gauge sending unit replaced on 2002 Tundra before 30K mi.
Had front differential and axle replaced on 2011 4R due to internal bearing failure at 46K mi. Did not abuse or take off road either.
I needed a V8 truck to pull my boat and after driving a Tundra I liked the Sierra better so here I am. Time will tell if I made the correct choice.
Welcome to A America Classic Brand,glad you made the switch,good info here.
Represent America Brand!
Someone ban this guy....you are only allowed to come here and bash the new trucks and discuss how you're giving up GM for Toyota.
OP welcome, I too came over from Toyota. Like many others, a former Tacoma owner who wanted something more luxurious, more spacious and offered better mpgs while offering significant more power. Toyota does make a good truck, but the bulletproof reputation of Toyota is overstated. My Silverado is no worse than the 2007 Tacoma it replaced. Only area my former Tacoma beats my Silverado is the resale value.
As a newbie myself, welcome.
After owing a 2011 F150 ( 5,0 FX4 ), 2012 F150 ( ecoboost Lariat ) and a 2012 F35 ( DRW 6.7 PS ) I decided to go with refinement and comfort over BS, hence the reason I am here as well.
I wanted a CC with the 6'6" bed, something toyota does not offer.
Also when looking at new and used Tundra's I noticed the used trucks had rust bubbling through the bed
around bolts that hold bed to frame. One was a 2013 with 30K.
Did not want to deal with rusty truck in a few years. Toyota makes a good truck but they do not seem any better
than GM from my past experience. My Sierra definately has a heavier frame than the Tundra and a much better ride. MPG of Sierra kills the Tundra as well.
Finally gave up the rice for some beef! Welcome!
I had 2007 Tundra it was OK but it had it's issues now have the 2016 Sierra so far I am not missing the Toyota at all.
Doubt I will either.
I like my GM truck better than my brother in laws Toyota truck, we go out every Saturday nite and switch of driving. He's since traded for a dodge, not as quiet as the GMC. As far as made in the USA, Tundra is made in Texas and some GMs aren't, just for your info.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
