Found this thread....   I did my lower ball joints about 3-5k ago (85K).  I noticed this front end popping noise while going through our local McDonald's drive through, before and after the lower ball joints.  Left hand curve and cambered. I just came in from outside and jacked up my front end.  Checked for TRE and bearing play.  Nothing.  Everything is tight.  My upper Ball joints were good when I did the lowers. The studs were not sloppy and had no play. I still hear this noise every now and then when going through the drive through. I torqued the lower and upper control arm frame bolts too.  I am starting to think it's a shock/strut issue.  Nowhere near bad enough to make me replace the shocks though.
Edited by FL335i
I had the same problem on my 2014 Sierra. It turned out to be a lose upper control arm. Tightened it where it mounts to the frame and well the knock was gone.
You might want to get the alignment checked.. The UCA bolts have cams and slots for alignment
Sent from my SM-G965U using Tapatalk
I did, but no longer have that truck.
  • 3 months later...
I have had my 2018 GMC Sierra checked for the front end noise three times and I was told it was normal! This makes no sense to me. Do anyone know of any recalls for this problem?
  • 5 months later...
Any update on this? I’ve had shocks, upper and lower ball joints replaced along with control arms. Dealer didn’t have a clue on what it was but wanted too tear down my front end for 500.00 bucks. Lol
Welcome to GM, this wont be the only time you hear this unfortunately.
Wheel bearing on its way out? Can cause a pop noise when weight is transferred to the other side of the truck (ex. turning) if the bearing is worn enough. Just replaced both on my 2014 1500. 105,000 miles. Usually you will hear a howling/grinding noise along with it though. Seems like you guys have replaced everything in the front end but.
Check your CV axles, if you have a torn boot it can get the universals dirty/worn out and make noise on turns also. I have also done one CV on my 2014.
 Checked the cv. Everything seemed good. No torn boots and not much play in them. Also checked running boards and there tight.
Check your exhaust, the flex pipe may be touching the frame. Im hunting a rattle in slow speeds and i think that is my issue.
I’ll check it out. This feels like a popping in my floorboard. Only happens when going over bumps and uneven surfaces.
  • 8 months later...
Hi, just checking to see if you got a resolution to the popping or clunking....same issue here.  Had it checked twice and the crossmember TSB retorquing performed, still does it - but I do notice it does it ALOT more when the humidity is low, and when it's raining, hardly does it at all....
  • 4 months later...
Hey Guys and Gals! I have read a lot of the comments about the "Clunk and Pop issue" everyone is having out of their Chevy and GMC trucks. I had the same problem out of mine. I thought it was an issue with the yoke at the back of my transmission and the dealership greased that. It still clunked when shifting into gear and was told it was the nature of the beast. So I drove it. I now have 57K on it and it had started creaking and popping along with the clunking. I took it to two local shops and both told me they didn't know what could be causing it. I took it to my dealership this week and told them the problem. What the mechanic found was a transmission mount was loose and several suspension bolts were loose. They couldn't believe they were like that. He said they are supposed to be torqued at the factory but obviously that had not been done. After he tightened and torqued all of it, it did away with clunk and pop in the driveline and suspension on my truck. I also called GM at the 1-888-988-7267 number and told them of the problem. I mentioned that I had read a lot of reviews about this problem. I was told by the customer rep that they did not have a lot of complaints about this issue. If you have had this issue you need to call and complain about it. Calling them and letting them know is the only way the issue will get resolved. They will send the complaints to the factory so the torque issue can be addressed by Quality Control. Just thought I would let you know in case you are still having issues with this.
My front end popping and hurling was from the ass hats removing the camber lockout inserts doing alignments. Put on a set of dirt king camber lock out plates about a year ago no more clunk or jerk in turns or tires wearing out too quick.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
