low beam and high beam issue
so i have a set of hids in my low beams and high beams i started having the problem of when i start the truck and leave the key in ignition both low beams turn on but once i put the truck in run position the left low beams turns off and i have to switch between high to low in order for the left low beam to turn back on this was about a month ago i ordered a new set of his for the low beam thinking well maybe its because I've had that set for almost 6 years. i connected the new set to the truck and about 2 weeks later i tried using my high beams and they worked fine but once i switched back to low beams both of my low beams did not turn back and i had to turn off the truck and turn it back on in order for my low beams to turn back so now i can't trust my low beams i have been driving with my high beams on for about a week and when i hit a bump sometimes one of the high beams turns off if someone can please help it would be awesome tomorrow im going to buy a new headlight relay see if that fixes the problem.
  • 3 weeks later...
The trucks using the low beams as drl tend to eat hid kits for lunch. I tried led and hid went back to halogen
