Longest lasting?
The Cummins was a good engine in a terrible wrapper.
I don't know, we had a '97 Dodge 1 ton, and the Cummins needed overhauled around 250k and had other issues afterwards... the body, on the other hand finally started to show rust on a few brush bashes on the front fenders. There was no visible rust in the rockers when it was sold with around 340k. Frame held up with being loaded to 13,000 pounds and being beat around in a pasture. Sold due to a persistent overheating issue that diesel specialist couldn't figure out.
Its replacement (Cummins) nuked itself at 200k and needed a rebuild... What are the odds?
Had nearly 300k on my 2004.5, and most of that was chipped...that truck went on average 20k between oil changes without a drop used and towed/hauled regularly. Lost one injector due to getting a tank full of water (drained gallons out of the filters). Body was perfect when I traded on this 2012. Same for the 99s I had before that...one had 250k, the other had 300k...the only issues I had with those two were lift pumps and the auto trans in the on (the other was a 5spd).
This 2012 silverado I have, a couple minor issues (frame beaming that was ture related, the TSB 4wd noise that is considered normal, and a broken radiator reservoir cap) in 90k miles, body is rust free, frame is rust free, is used to tow/haul more often than my previous two Cummins!
As was said, take care of them and they last...
I'd love to see a graph of each of the truck brands in the form of a bell graph telling you how long they lasted until they died.
AAEAAQAAAAAAAAO3AAAAJDJlMDM1ZDU0LWI1ZGIt
I imagine the Ford and Chevy curves would be pretty tight, with a few lemons that are done after 10 years, most lasting around 15-20 years, and a few that last 25-30 or more years.
But I'd be willing to be Dodge's graph would be just a flat line. You'd have about a 1/3 that die rather quickly, just as many that last 15-20 years, and another 1/3 that make it to the 25-30 year age. When a particular Dodge truck is reliable, they seem to be rock solid. But there's just as many out there that are basket cases and nothing but trouble.
Let see GM has the oil burner becouse of the V-4 nonsense in the pre 14 engines. Ram is having lifter and timing chain problems same reason. Ford with turbo V6 problems in thier trucks. Interesting to see in ten years who has the title for long lasting. I'm guessing it depends on how many 1/2 ton deisel Ram sells or Tundra maybe Nisan
Definitely a cherry picked stat. Seeing how GM sells 5 times as many Silverados a year compared to the Tundra and Ford 6 times as many F150s, even if half of both GM and Fords were put in the scrapper in 10 years, there would still be more of each still on the road than the Tundra.
Are we counting the 500,000 2012+ dodge rams that fiat chrysler was forced to buy back last year because of unservicable recalls?
http://www.theglobeandmail.com/globe-drive/news/recalls/fca-must-offer-to-buy-back-500000-pickups-due-to-recalls/article25718461
When I was shopping in 2015 I did not even look at a dodge because of this reason. GM, Ford and Toyota are the only good trucks. Regardless of Dodges past it is not even close to the same company today.
Saw this ad the other day, from the disclaimer they put:
Based on IHS Automotive VIO registration data for all brands of GVW 1-3 pickup trucks continuously sold in the US since 1988. Dodge and Ram have the highest overall percentage still on the road.
this is horseS***, just because it's registered doesn't mean it still runs.
Hypothetical here, suppose there's 2 million chevy sold and from that there's 1 million that is registered, that's 50% of registered ownership..
but if there were only 500,000 toyota's sold but 400,000 were registered that's 80% however, based on the number of "registered" data, Chevy's number is higher but only half the vehicles bought originally are on the road.
I know I own a chevy but should've gone with (fill in the blank)..
anyways, 1 million miles on this Tundra.
http://www.trucktrend.com/features/1602-the-million-mile-2007-toyota-tundra/
Exactly, they make these claims and skew numbers to fit their agenda.
    • No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.   I think this is what I'm looking for.   3000 ORDER ACCEPTED BY PRODUCTION CONTROL
    • Then you haven't read your book. It also says check every 400 miles.   If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
    • Following up on my topic, I put an O2 sensor in it which seems to have got rid of all the b2s1 codes (I ended up having multiple codes). Next I’ll try to figure out the P0011 but I might focus on exhaust manifolds first, they’re getting pretty rusty. I’m hoping this thread will help someone in the future.
    • I’m going off the instructions.
    • My expectations are a bit higher.    No faded paint or dry rotted plastic/rubber. I use a dressing and a ceramic sealant. No hazy headlights.  No door dings. Small dent in the front bumper. All rock chips repaired. No brush scratches. No windshield chips. No fender benders. Limit damage due to a proactive plan the included ceramics and PPF and prompt attention to any exterior issue. NO RUST. Stays out of the salt and had the rear wheel wells Line-X coated as well as the bed which has a bed rubber and has been under cover since before I bought it. Washed and detailed regularly. Rex chewed up the tow button, got whacked and the button replaced the same week. He's leaned his lesson. If I can train a dog the kids are easier.    All suspension is original save the King Shocks I installed very early on. 50 years ago dad told me a good shock will keep the screws in the dash tight and the front end mint. He was right. Everything within new spec yet, tight and aligned well several times. Coolant system is OEM save the modifications I made early on. Not a single leak anywhere on this machine. (Did repair an intake leak on #4 during the HPFP replacement.) The injectors I replaced didn't need to be. They checked out great. One of those, while I'm in there with the manifold off and the fuel rail apart things.  Not a stain or abrasion one to the upholstery. Have kept is covered since new. Never had a carpet, it's a work truck but the carpet squared I laid on the floor have keep the factory rubber liner MINT. Ceramic wind tint helps preserve the interior.    Original BRAKES with 60%+ left of the pads and rotors mic excellent. We just did a full preventative brake service. Disassembly, clean inspect including measurements, lube, Dot 4 power flush including ABS system.    OEM battery. OEM vacuum pump. In fact the only things not OEM are a pinion seal the high side pump and injectors and a small plastic shield around the starter. All hoses/belts etc.. are still in service and doing well. Original tires lasted 125K and had I known some additional details would have made it to 150K with legal tread. (Date out is six years, not 5 and Continental says they are good for 10 so I pulled the trigger to early)   I never let my children or grandchildren run the show. Feet on the floor and hands in your lap. Dog gets a pass.    A truck is a machine the gives you back whatever your willing to put into it. Same as a computer or a butter knife. I use a shovel but I scrap it, hose it off and oil it when I'm done with it. My original spade I've had 60 years.      Set the bar higher...you spend less money. No, before you ask, I have spent a fraction of the cost of a new truck in my entire maintenance program including disposables, filters/fluids etc.
