New Recall-Airbag/Pretensioner Not Deploying
dave07
You can always check HERE or HERE as well. Just scheduled mine for the 2016007 recall service this morning.
Or, in Canada, https://recalls.gm.ca/#/
First recall on my truck. At least I don't have to have my seatbelt hacked up.
  • Replies 49
Does anyone know where in the trucks is the SDM? Is the SDM reprogrammed by connecting a computer directly to the module?
So I was in a wreck 11 days ago, rear ended , and my seat belt broke and no air bags deployed. In the body shop now. Prelim estimate is like 24k. Do I contact GMC or just stay with my insurance?
Airbags do not typically deploy when being rear ended as there is no need. Seat belt breaking is an issue, but not the non-deployment of airbags in this case.
Yes, I assumed that my air bags would not deploy however, since it was more of a rear right side impact the body shop was really shocked that the side airbags did not deploy. also they was confused as to why the seat belt broke.
We just did about 150 at Uhaul in our area. We have a large fleet of GMC 1500's. Programming took about 10-15 minutes.
Just checked and mine is listed in the recall. It is at the dealer already (for other issues). So I guess I will call them and have them fix this too if it is just a simple reprogramming.
Yeah, like has been mentioned, the reprogramming only takes 15 minutes or so. They disconnect the battery, reprogram the SDM, hook the battery back up and send you on your way. I had it done yesterday when they did my oil change. Lots of vehicles in the recall, 4 mill +, it looks like.
I brought my truck to the dealership today for a completely unrelated 'moaning' noise under acceleration - dealer said they would take care of this at the same time.
Can't program with a disconnected battery.
Well, that's what they told me. All of my mileage info was reset, so it seemed logical.
Sent from... um... where am I again?
Yeah they cant disconnect the battery and reprogram anything.
Had mine done today and mine wasn't reset. What may have happened to yours is that maybe it didn't reprogram right the first time or froze or something like that so they might have had to reset it to try it again.
That makes sense.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
