1 hour ago, 15BlueSilverado said:
Unfortunately, my 2015 Silverado fell victim to the same issue right around Jan I think. Luckily it hadn't been too hot after so I didn't think much of it until I started searching for the cause. That's when I came across all the thousands of issues and complaints for the same thing. I took my truck to the dealer where I purchased it only to have them tell me that they didn't have any AC service techs working on a Saturday AND that the part wouldn't be covered under warranty. Oh man was I pissed considering my truck only had like 32k miles on it at the time so it should have been covered under warranty. Anyways, I've filed a complaint and I actually found a replacement online for under $100. I plan on fixing it myself and then having a friend with mech shop recharge the system for me. It really sucks that GM hasn't issued a recall for this issue yet, I'm seriously thinking about trading my truck in for a Tundra after this.
UPDATE: So I decided to call the dealership one more time during lunch to see if I could get more info. This time, I was told that my truck was still under the bumper to bumper warranty, which I knew the first time I called considering my truck had like 32k miles at that time, and the repairs would be covered, which is great but now I have this $100 condenser being shipped to me that I no longer need. Anyways, I proceeded to make an appointment for this Thursday to have it fixed. Figure since it's covered by GM, might as well let them fix it and it'll free up my time this weekend to do whatever else comes up. Still considering trading it in though.
On 5/21/2018 at 12:01 PM, 15BlueSilverado said:
... but now I have this $100 condenser being shipped to me that I no longer need....
Keep it. You are gonna need it when your warranty expires.
The general theme among this forum and most GM truck owners that I know is that replacing the AC condenser is pretty much a yearly occurrence. Even on the new part models, apparently the flaw in the condenser still exists. Another problem that GM can't be bothered to a find a solution for.
Unless you plan on trading the truck in, I would budget for it to be a yearly expense.
Uhm, yeah, I think that might be a tiny exaggeration.  Has even one person on this board replaced the condenser every year?  While it's certainly a known problem with an apparent failure rate much higher than it should be, there are a whole lot of owners out there like me--4 1/2 year old truck, still on the original, AC still cold as ice....
Too late, already returned it for a full refund.
I've never heard of anyone having to change theirs out on a yearly basis. I know there's flaws or were flaws in the craftsmanship of the condensers but once replaced, I haven't come across anyone that had the same issue within a year. Since I had it fixed, it's been running great in this TX heat and thank God!
I plan on keeping this truck till it just can't drive or run anymore and when that happens, I'll replace the motor and keep driving it.
A lot of folks here are saying GM should issue a recall which is amusing.  Understand that recalls are only issued for safety concerns and where death or injury can occur.  Air conditioning is not a safety concern, therefore they will never issue a recall for this. What will happen is they'll quietly fix the issue on newer trucks, and see what happens to the existing customers.  Out of those owners who's AC will break, you'll have 2 groups of people.  One group will complain and do research and speak to managers and demand help and they'll get some form of assistance from GM it sounds like for the repair.  Most though will swallow the painful pill of paying the full price to get it fixed and that's what GM is hoping....to spend as little of their own money as possible to fix a poor design.  That's just the reality of the situation.  So hopefully you're still under warranty.  If not and your AC breaks, be prepared to fight a little to get some help.
Me personally, I have a 2014 with 60,000 miles and so far the AC still works, but I'm expecting it to break before 100,000 miles.  I'm way out of warranty now so I'm going to have a fight on my hands when it does.
Edited by Silverado-Hareek
Of course its an exaggeration. The problem is that no one can say exactly how much of an exaggeration it is. GM doesn't release their defect data (why would they) so we are left with personal anecdotes, speculation, and a whole lot of confirmation bias.
Reading this and other forums, its clear that GM has a defect with their condensers. It would be hard to deny that at this point. This wouldn't be such a problem (all vehicles have their shoddy parts), except for the way GM has handled this.
There are cases ranging from 2014 all the way up to 2018s with the exact same issue. That's four years where GM has failed to address a defective part. It seems reasonable to conclude that if GM hasn't fixed their condenser model in nearly half a decade, they aren't going to be jumping on a fix any time soon. If you stuck a OEM part in as a replacement, then you can expect its just as likely to fail as the last one. It may not happen every year, but the odds of it happening again are way higher than they should be.
I would think that if you have to replace it, go with an aftermarket part. I'm glad you guys have had good resolutions/experiences however.
They did address it.....with a brand new 2019 truck ?
That may be how I address it too. Won't be a GM though.
That being said, there is no promise that the 2019 models won't use the same shoddy condenser.
Supposedly, the condenser has already been redesigned on the later model K2's.  The 2019 likely utilizes the lessons learned from the K2 trucks.  Still, I personally wouldn't buy a 2019.  After owning a first year model run 2007 and 2014, I've learned that you really should give a new model a few years to work out all of the bugs.  Reap the benefits of the early adopters.
Wife's 2015 Buick Encore (GM) condenser went out about 7 months ago, just out of warranty.  Leaking from a seam.  When I took it back for replacement ($1,100.00) once the part came in the following week, service manager told me that they (GM) had noticed a problem with the condensers for that year.  He knew I also had a 2015 Silverado and told me the next time I brought it in for service to have them check the condenser.  Wife was scheduled to take it in last Friday and she told me the Tuesday before that the A/C was blowing warm air.  Also just out of warranty.  While there they noticed that there was a leak along the seam and it needed to be replaced, $1,200.00. Drop it off this Wednesday for the replacement.   I do have to admit that the service manager was able to get a little GM assistance with hers and I believe he was able to get a little with mine, so that helps.  I can see where this does not look like a wide spread problem, but if the service manager has known for a while, and both of our 2015's having the same issue, it kinda hits me a little harder.  Die-hard GM guy here, so just venting a little, not going away.
I thought I was going to be the lucky one who didn't have this issue.....unfortunately it got me as well. New condenser and hose bracket this morning, now I'm back on the road. My truck is a 2016 with 65k miles.
  • 4 months later...
So I have a 17 Sierra 1500 that I bought new, I got about 43k on it now but the ac stopped working and the condenser has a leak. Dealer quoted me $1597 to replace and recharge the system. I called GM because I’m over my miles and they denied me for goodwill. Anyone else have their condenser go out on their 17. I’ve been reading the post and everyone’s that been having an issue are on model year 14-16.
Well just had my ax condenser stop. (2014 with 69k) as I googled possible issues I was quickly sure I’d what the issue was.
picked up a replacement at oreillys for $150 and $30 in 134a plus a few hrs and all cold again .
Definetly nit not worth paying a dealership to replace it and with the same crap that was the problem. Simple DIY vids on YouTube.
I'm about to replace my condenser because there is no way I'm spending $1.1K for this simple repair. I have a couple of questions though. The Murray unit I see at O'Reilly's is P/N: 7-4283 and it says it is an "A/C Condenser, Oil Cooler And Drier Assembly." What is meant by oil cooler? Is the condenser on these trucks a combination unit that is used for the A/C and a transmission oil cooler or something?
EDIT: Finally found a video that touched on it briefly and it looks like my suspicion was correct that the transmission fluid is affected. I'll call up the dealership on Monday and get a quart so it's on hand for this job.
Edited by Dunc
My 2015 AC won’t keep a charge.  Was your condenser leak in upper right corner facing grill?  Freaking annoying!  My left side lifters have already been replaced now this shit?
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
