Called again it is the new GM redesigned condeneser.
I'm curious to see how GM has addressed the condenser issues compared to how the aftermarket has approached them.
Judging by what I've seen and someone mentioned here a few posts ago, I'd say that the dryer wasn't welded properly to the condenser.fec389ec93cd19341bdbd66038227dcb.jpg
Edited by mois93da
Btw I had to refill the refrigerant again Sunday and I was on the road, I just happened to have my mani gauges in the truck, and my kids and wife were in there with me. I pulled up to o'reily and bought a can tap (happened to have a can of r134 in the truck too) because I had a half can still at home. When I went up to pay for the tap I got curious and asked the gentleman if he could look up a condenser for me, and He says, "we don't have any here but we show three in Houston. Needless to say, i paid for it right away, and went to pick it up. Did the install on Tuesday. It comes with a lifetime warranty.
  • 6 months later...
well my A/C went out yesterday...thoughts??  I don't think it is compressor...
anyone replaced theirs themselves?  thinking it is the condenser...from my research.
im not seeing signs of leaking on the line itself...just the condenser...
i do not have the bracket on the line either.
2014 94k miles
Edited by JUSTINASS
2014 94k miles
You’ll need a new condenser and an upgraded/modified line set (aka, a couple of hoses with a Chinese manf clamp :/  )
yeah and i ordered the hose off of amazon and the bracket...got a condenser from autozone...
are you saying there is a better modified line available? can you expand on this info?
The line set is, as far as I know, the same. The bracket/clamp is simply two pieces of metal that span the compressor inlet and outlet to brace them. If that’s the bracket you have, that’s all I know of.
Are the 2017's ok or is this something to look out for?  Mine has a build date of February 2017, and by reading this thread, it sounds like the redesign parts may not have been in production yet?
I just joined the party, My Condenser went out at 67,000 miles. What a joy! I am a little late on this thread but I wanted to get some input from the guys that have dealt with this issue already and what seems to be the best route of action. The way I see it I have three options.
1. Call my local dealer, charm them and try and work out the best possible price.  - my least favorite route.
2. Buy the Condenser and replace it myself. (would you recommend the AC DELCO or a aftermarket brand)
3. I have a good friend with a welding/Fabrication shop. We possibly will be able to do the nitrogen purge and weld that sucker. I am just not sure how the process goes.  < my favorite and cheapest route.
 If anyone has the information on how to properly flush the system with nitrogen and weld it. I am all ears, If that cant be done I will explore the other options.
Thanks in advance.
thought i would update to help others out....
i got the murry condenser and replaced it myself... i think it was around $60.00
i also bought the bracket from amazon...$8
my line looked perfect and didn't show any signs of leaking so i didn't replace it.
after replacing the condenser i took it to a local a/c shop i trust and had them pull a vacuum and recharge it...they charged me $100.
overall pretty simple install minus a few bolts that are hard to get to on the underside of the radiator support.
sucks knowing that this is pretty much a defective part from the factory and i had to waste a sunday afternoon fixing it...but i do have 92K trouble free miles, so i can't complain too much.
thought i would shed some light...
summer is gonna be upon us soon and guess what no ac and i'm in the south!!!
researched problem and i found this thread.  Gm dealer gave me parts at wholesale price so i decided since i am in there might as well replace KNOWN ISSUES..   so i replaced....
1) condenser
2) high pressure line from compressor to condenser
3) installed updated bracket
4) two band aids later
5) pulled a vacuum and it held (fingers crossed)
not a hard job just be ready to cuss the 3 bolts on the cross member (each side) that are on the bottom
(note video is same for a 2014)
  • 2 months later...
Unfortunately, my 2015 Silverado fell victim to the same issue right around Jan I think. Luckily it hadn't been too hot after so I didn't think much of it until I started searching for the cause. That's when I came across all the thousands of issues and complaints for the same thing. I took my truck to the dealer where I purchased it only to have them tell me that they didn't have any AC service techs working on a Saturday AND that the part wouldn't be covered under warranty. Oh man was I pissed considering my truck only had like 32k miles on it at the time so it should have been covered under warranty. Anyways, I've filed a complaint and I actually found a replacement online for under $100. I plan on fixing it myself and then having a friend with mech shop recharge the system for me. It really sucks that GM hasn't issued a recall for this issue yet, I'm seriously thinking about trading my truck in for a Tundra after this.
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
