1 minute ago, Marv88 said:
I asked a similar question but wasn't able to have it answered here so I researched elsewhere and found you just need to replace the steering wheel along with the clock spring to control an aftermarket headunit as the signal is picked up at the clockspring unlike with the factory radio. If you get the idatalink Maestro as well you will also be able to maintain "most" of the other functions in the factory radio as long as the headunit you choose supports idatalink however I haven't had a chance to install mine yet so i don't know what those functions are.
Great news! Thank you!
I was at the point where I was going to pick up a new steering wheel just for the leather upgrade, so this is awesome.
You're welcome and one thing to note is if you go with a typical double din headunit you will need to cut the plastic support rails for the factory module inside the dash (the Alpine Restyle is the only one I am aware of that does not require any dash modification)
On 10/7/2016 at 5:31 PM, Harlech said:
Well after some work and some digging and some wiring I have finally completed the retrofit of my RCSB Blackout (Which was the WT trim with the small radio) to have the IO5 stereo, Color DIC Gauge Cluster and Heated Steering wheel with all the controls working, both the DIC and the stereo controls work. I would guess that total I have about $2000 tied up in all of this so it can get costly and it isn't for the feint of heart, you will be cutting into factory wires. This will only work if you have the IO4 option code, if you have the IO3 stereo you are probably out of luck.
Gauge cluster programming was provided by Chris over at WAMS, I highly suggest going to Chris for all your custom module programming needs. He is a busy guy so if you have questions on this swap you will want to post them here as Chris won't be able to help you out with anything other than providing the custom programming for the cluster. You can request prices from his site at: http://www.whiteautoandmedia.com/
All of the information needed to do this retrofit can been dug up from the upfitters electrical manual available at: https://www.gmupfitter.com/pages/body-builder-manuals
If you plan on attempting this familiarize yourself with the information I post and this manual, it will save you some head aches.
Basically all you are doing is tying back the steering wheel controls to the gauge cluster on the LIN Bus (one wire, that doesn't exist if you don't have controls) and then adding the gauge cluster to the MOST bus via the stereo. This is easily done at the radio module behind the HMI (The top box, but you know this if you have upgraded to IO5 or IO6) just with the grey 8 pin connector which actually is where it shows the gauge cluster being in relation between the amplifier and the radio. You will want to put the gauge cluster in series on the most bus on wires 3 and 4 from the far right connector on the radio module. So basically you will cut these wires and where they were going in to the radio now they will go into the gauge cluster on pins 1 and 2 and the return to the radio from pins 17 and 18 on the gauge cluster, all this can be found in the upfitter manaul. Then you will want to grab the MOST enable signal from wire 7 on the connector and bring it back to the gauge cluster also, you can tap off of it.
If you have any questions feel free to post them here and I will try to stop in every so often and answer. PM's will go unanswered as I don't want to type the same info out 20 times so just post it here so we can have one post covering this. I will also try and post some diagrams and more pictures next week along with a link to the pins that plug in to the blank spots on the connector of the gauge cluster to add the above circuits.
But yes, this can be done.
Thanks,
Kyle
My truck is a 2017 Chevrolet Silverado Regular Cab WT 2WD IO3, But I have recently upgraded it to I05 via an MVI kit, so now I have the HMI Module and everything.
I would like to do this mod as well, I got such a great deal on this WT, I had to buy it, and knew everything else could be upgraded, but shed a tear about the cluster and steering wheel, so I've been searching on how to make this work.
I contacted whiteautoandmedia and was referred to this thread. Any help appreciated!
Thanks!
Thanks!
When connecting to the clock spring harness, you mean from the steering wheel to the clock spring? Pretty much on the steering wheel harness?
Sent from my LG-H918 using Tapatalk
Thanks!
I agree with you on the looks and functionality of the cluster and steering wheel controls. It's easy enough to do just study the connector changes. Don't mind the flow charts of circuitry these are just letting you know what circuit your adding it to.
I purchased a new steering wheel (with the voice controls duh)
a new clock-spring
a new gauge cluster (I wish I would have bought a denali gauge cluster because they are so sweet, all LCD)
I tried it first without swapping the clock-spring but the voice controls didn't work nor did it light up at night. So swap out the clock-spring.
a new clock-spring
So all I have to do for my io3 W/T that was upgraded to IO5 (via MVI kit) is get a new steering wheel, a new clock spring, and new gauge cluster, then just have it programmed to my truck, then install and I'm good to go?
Yup, I had these guys program my gauge cluster for my truck. Also, just double check behind the infotainment LCD that the radio connector A11 Radio X2 is there. It should be but ya never know. Check the image.
I think the guys name is Chris. Check out his website fully before sending or contact him first because hes specific about shipping.
Does your year truck have an HMI behind the passenger compartment? Just wondering because I thought I read something about i03 trucks not having an HMI. :/
*Addition - you will have to buy a spool of 0.5-mm (I think that's 22 gauge in AWG) wire and the female terminal pins for adding the wire to the gauge cluster connector and wiretaps or know how to solder.
Edited by Reyesarg
It did not have an HMI, but since the IO5 upgrade it now does, I installed it behind the dash screen.
When you connected your wire from the cluster to the wheel, which connector on the wheel did you tap into? I can't figure that one out as my wire colors don't match OP
Thanks,
Kyle
Edited by Eliot
Hi Everyone,
First of all thanks to Kyle and those who enriched this great mod!!!!!!!
The other subject I would like to share is that I follow up to the letter this mod and everything worked perfect, but experienced several good things for you all to knwon. First I own a 2017 Chevy Silverado 1500 WT (Assembled in USA) which had io3 system. On a trip to a dismantler bussiness (El Tapatio Dismantler, near San Diego California) bought for $120 USD 10" touchscreen, HMI (2.0), Radio Module, Color cluster Gauge, and telematics module. I took my truck to a local shop in order to make the Upgrade (To io 5) and they were able to program HMI only, they could not program Cluster Gauge nor the Radio Module, therefore only 10" Touchscreen worked fine. Last weekend I started to review upgrade wiring according to pgamboa advice (Thanks for that) and found two missing wires on the HMI module, after connecting the wires the bluethooth still did not worked fine, so decided to replace io3 radio module for io5 radio module and everithing worked fine, even though owner of the shop told me they were not able to program radio module. Once I did the swap (io5 radio module replaced io3 module) bluethooth worked perfectly, radio, cd player, everything worked fine, but most surprising thing to me was that today I took the risk of doing the color cluster gauge mod without knowing if it was a compatible part number nor being programmed by whitautomedia or local shop, and everything worked perfectly!!!!
    The questions that suddenly emerged are:
   Am I a lucky bastard that found 100% compatible replacement parts for the upgrade? or only HMI module requires programming? since radio module nor cluster gauge were reprogrammed before I install the Cluster Gauge. The only indicator that appeared when I switch the car on was "Theft Deterrent active, close and open Driver Window" I did it and that was all, rigth now cluster gauge is beautifull compared to monochromatic.
   I am attaching a bunch of pictures so you can see I am not lying about this project. I am not trying to hurt anybody´s bussines but I belive we have to realize that may be only one module needs reprogram in order for the rest of modules to activate, or maybe doing the complete rewiring will put to work the rest of the modules. I would like the input of an expert on this.
BajaKing
Hi Everyone,
BajaKing
5b218a3845e20_usedcolordisplayclustergauge1.thumb.jpg.a9f33f91f070cdab542a443aa43726a1.jpg
5b218a46d6fc6_Usedcolordisplayclustergaugepartnumber.thumb.jpg.18d1d7c3685575a4403c107d2a0fe2e3.jpg
5b218a50252dc_ORIGINALMONOCHROMATICCLUSTERGAUGE1.jpg.d915d9642f8bb79dfcb57b3fbe3e25ab.jpg
5b218a70f31c6_replacementcolorcluster4.thumb.jpg.1a3ef03ddf7bf0252c7ba2a6a476bf11.jpg
Well that’s interesting
3 hours ago, Eliot said:
Hi Everyone,
BajaKing
Weird, I also have a 2017 Silverado WT, that I want to do this upgrade to, I swapped my IO3 to IO5 after programming through MVI, 8" screen, Apple Car Play, Android Auto, Bluetooth all work fine.
So like I asked earlier in the thread, if I have the IO5 radio, shouldn't a new cluster just plug right into the radio? I too would like to know if the cluster still requires programming for this, because I would like to add a Denali or High Country cluster.
Next, what do I have to do to swap my steering wheel out that has no buttons on the right side, to a steering wheel with the buttons, so I can control the cluster?
And BajaKing, if you had an IO3 W/T, how are you switching screens on the cluster?
Dmac1984,
I did swap the complete cluster gaige for the color clister gauge, not only the color display, but additional to this, follow the wiring mod that Kyle wrote on this thread. If I were you, will search first for a compatible color cluster gauge ( I took the risk and did all the wiring, whether the color cluster gauge was compatible or not) asking to Chris at whiteautomedia.com so you can get a compatible cluster gauge with your truck and the follow Kyle instructions on the wiring modifications and install it. If it does not work, then send it to whiteautomedia for programming. Remembre that tou are doing this at your own risk. I am sharing my risky experience which came to a happy end.
My 2 cents.
BajaKing
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
