My shaking issue has been fixed so I will tell you what fixed mine and I would almost guarantee this will fix them all.
I was building up my 6l80 with some performance parts and sent my shaft out to a local shop to check balance, he said balance was perfect but it was out of true...meaning when he chucked it in his lathe it had 1/16 of an inch of runout in the center of the shaft. It was so bad you could obviously see it when spinning so he trued it and now my truck runs as smooth as glass with no shake, no shimmy, no vibration, nothing, it's never driven this good ever. So take your driveshaft out and have it checked. BTW it only cost me $86.00
RT
  • Like 8
Would you mind sharing with us what your symptoms were before-hand? Ive got a big torque converter shudder issue. My truck shakes like mad, shifting between gears and under light throttle. Torque converter was replaced and nothing changed. I also have and 8 speed with the 6.2 though.
Well my symptoms where just that.... a SHAKE! It would shake between 50-60 the whole cab would shake. It felt like King Kong was trying to shake me out of the truck. I could even feel it in the steering wheel at times it was so bad. I had my converter checked for balance in it checked out fine.
RT
  • Haha 1
No tach jumping, constant between 50-60. below 50 nothing above 60 nothing. Just get your ass under the truck remove the shaft and have it checked no need to look further.
RT
Edited by 07Softail
How about the 2500 HD trucks?
Sierra Boy
not sure if they are have these issues but def half tons. The shop that fixed mine said he has fixed a ton of Dodge trucks too both shafts are made by AAM
RT
Edited by 07Softail
RT
Well,
It cannot hurt to spend $100 to find out just how bad they are and how much better they can be! It has to make the whole drive train last longer so all in all...worth the effort!
Sierra Boy
Edited by Sierra Boy
I think the concept is fascinating and makes perfect sense, any rotating part that is not running true can easily produce a shake. This boy may have cured the 800 page shake and vibration issue thread!! How would we find this shop that does good driveshaft work?
You could check it yourself with it still in the truck. Just put a dial gauge on a good sturdy mount or base with the back wheels raised and watch the dial indicator as the driveshaft is rotated by hand.
Sent from my SM-T817V using Tapatalk
Exactly!
RT
RT
Also one detail I saw that you mentioned in the other forum that I think might help people
The local shop took one look at the brand of your driveshaft and said, "yup that's the problem"
Apparently the manufacturer of our driveshafts are known to have this issue?
I emailed them a long detailed message about it and of course no response. I am thinking there Quality Control or lack of is in question. We will see if they respond or not. BTW they are made in MEXICO! LMFAO!
RT
RT
0.0625''? that seems like a mile. how did they check it? did it have ton of weight on it? I'd expect .015'' as normal.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
