This 2 wheel RWD right? I had an 88 4wd S10 Blazer. Stock lift. After moving out of areas where 4WD was necessary, the next tire set was a passenger car type tire. Wasn't going to drive it much didn't want to put a large amount in tires. But it did look a little goofy with that highway tread design
I had really good luck with Hankook tires. 1 set for 1/2 Chevy PU. 1 set for Toyota Sienna and 1 for Lincoln town car. They all performed well. Pleased with the performance especially on the Sienna. The Kinergy replaced the model I had on all 3.
Cooper makes a good tire, I like the look of the tread since it does look a more "off road" ready.
I'd probably pick the Cooper for the looks
Any rebates on anything?
Used to be Discount Tire was the place to buy at any Holiday. They had specials/rebates etc... on sets. Haven't seen anything like that done in a good while. Just a manufacturer rebate occasionally.
Cooper tires are made in USA. Either Arkansas or Mississippi, iirc
For a limited time, Preferred Customers and online/catalog customers get a free magnetic level with their order of $100 or more when they use code LEVEL726 at checkout. Offer ends July 28, 2026.
Save up to 25% off retail as a Preferred Customer. Sign up here. https://www.amsoil.com/p/preferred-customer-registration-preg/?zo=521390
As always you can order here. https://syntheticadvantage.com
Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.
"Dirt cheap" (<$100/each)
Starfire Solarus (AS or AT)
Rocky Mountain HT2
Mohave HT
Westlake SU318 H/T
Laufenn G FIT
Entry Level AS (yes, Entry Level is the name of the brand!)
"Somewhat cheap" (<$150/each but >$100)
Kumho Solus TA51a
Ironman (Les Schwab)
Cooper Discoverer RT AT
Hankook Kinergy ST (H735)
Milestar Patagonia H/T
Toyo Extensa AS II
The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.
Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.
If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.
In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
