Underseat Storage
Hi Guys, I'm awaiting delivery of my 2017 2500HD crew cab and looking for a viable underseat rear storage container. All the containers I've looked at require lifting the rear bench to access.
Unfortunately, I have the car seats for my 2 and 4 year-olds in the back, lifting the seat with them in place is impossible, and removing them is a PITA. Does anyone know of any other viable options? Otherwise, for those who have one, is there an easy way to secure it in such a way that it'll mostly stay put unless I pull it out from under the seat to access it?
Thanks,
Boats
I haven't seen an underseat storage that pulls out like a drawer like you'll need. Sounds like something that will need to be custom made. Maybe you should consider something for the bed instead. There's plenty of options for bed storage, not just toolboxes.
Well i thought my situation sucked, yours is worse. I have one car seat in the back and put it on the passenger side as that is the smaller seat and i use the gm underseat storage. That allows me to access most of it. The problem comes when i am in the garage. I park with my passenger side againts the wall and have to pull out to load my daughter or unload her before pulling in the garage. I'd love to have her on the driver side but then the storage is about useless.
well, you could have 3 car seats in the back like i do. :nonod:
So what's the real question? A better underseat storage OR a better form of birth control? Haha just kidding ya.
I have only seen homebuilt wooden underseat storage that does anything less than make you flip the seat up.
I am feeling sick just reading this, and very very poor!
Lol, yeah. Someday i'll be able to lift my seats up and actually get to the storage area underneath.
Thanks,
Boats
If you have a floor liner in the back all the way under the seat, i would think one of those underseat storage options would say put for the most part and you could just pull it out if you needed something. Could also maybe put some of that drawer liner stuff underneath to give it a little bit of grip?
at some point, i'm going to look into building a box out of wood.
Another reason I'm glad I haven't had kids yet at 31. If I did have any I wouldn't turn away, but I'm just fine to not have kids. I'm the type that can be good with kids but I want to give them back to their parents. So I'm the Uncle I guess lol.
I also just thought that you could get an underseat storage and just not mount it so it can pull out. It wouldn't as easy as a custom drawer type storage, especially if you have a good amount of weight. The only problem would be to secure it while it's under the seat. I have the GM one and it only mounts to 2 seat bolts.
That was my second thought. Put some industrial velcro on the bottom, or maybe re-route the straps around the front so that they can be released without lifting the seat.
It doesn't need to carry anything heavy, that's what the boxes in the bed are for. Just my trauma bag, a bug out bag, some outdoor emergency supplies, etc.
My guess is that it wouldn't slide out under normal driving conditions. If you went with the velcro straps, perhaps you could put them on the side of the box that faces the back of the cab. Then just slide it in and attach the velcro.
I had the same problem. I looked into custom building a storage unit that would slide out that was covered in leather, with rails and everything. Then my wife walked out of the department store one day with two black plastic underseat storage bins that cost I think $18 a piece. Now I have storage that's easy to get to without removing a car seat. She's driving my truck today so when we get home I'll post the brand. It's not a full width solution but it works really well.
  • 1 month later...
Did you ever get pics of this? I'm in the same boat, car seats not allowing access. I wouldn't mind getting one of those lock boxes if they made one that only went 60% across the back. I still want a sub under the other 40%. I want to carry a whole bunch of stuff-and not have to look at it!
I'll take a pic today. Now if I'm smart enough to load it on here from my phone is another story lol. That are open plastic bins that don't lock, but work well.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
