I have had my 2015 Silverado 1500 crew 5.3 for the past year. One of the many things that I loved about my truck was the fuel mileage. I always averaged 19 to 21 mpg. I am usually driving about 65 mph. When I got my service done at 15000 miles at the dealership I started to see a drop in mpg. I have kept my eye on it and I have taken the truck in for another service and now 6000 miles later I am still getting anywhere between 15 to 16 mpg. Nothing I do changes it. Does anybody have any of an idea on why it is doing this. The dealership doesn't have an idea. Thanks
You've had a lot of great feedback to your post, but how about a simple test? Trade truckswith your brother for 1 tank or 1 week or 500 miles, enough normal driving to determine if it's the truck or the driver.
A Red X study? In a Red X study you swap things between a BOB and a WOW and look for differences in the results. If you were to swap with your brother you'd be swapping not only drivers, but locations/routes, payload(?), and maybe fuel sources.
A few more ideas. Combined with ideas in previous posts
  • Swap Drivers, etc
  • Keep an eye on steady state V8 FE @ 40/50/60/70 mph and compare with brother or others on GMT.com
  • Keep an eye on AFM/V4 operation. Any noticeable difficulty in achieving AFM?
  • Keep an eye on instantaneous FE while coasting. It should read 99 mpg after a short amount of coasting. This is due to DFCO operation (no fuel consumption). This is a big one.
  • Keep an eye on 25/50/400 mile FE average. Do you get poor FE even on a 25 mile trip with mostly 55 mph cruising?
  • Any Remote start idle time?
  • Tire pressures ok?
  • Excess weight in vehicle? Tools, etc?
  • Try premium (even if winter fuel)
  • Check oil level, oil type?
  • Check air filter
  • Check average speed to see if low (more idle time/low speed-city driving than others)
  • Any 4WD/Auto 4WD usage?
  • Verify DIC Calculation by calculating manually
I calculate mine manually every tank and it has been within +\- .1 of the DIC.
You are an anomaly.
You are an anomaly.
Make sure you turn your truck off then turn it back on before you compare. It seems like the mpg average will correct itself on a reboot. I consider the mpg shown while continuously running to be an estimate and after the restart to be the actual number.
You are an anomaly.
  • 2 years later...
There are many variables that affect mileage such as: tire inflation, the type of fuel, weather, elevation, the speed at which you drive, the gear in which you drive, the speed with which you accelerate, engine maintenance, excessive idling, cruise control, the grade of motor oil you use, and of course etc.  In short, mileage is complicated.
H
On 3/7/2019 at 10:24 AM, MICH 5.3 2016 SILVERADO said:
My last 25miles show an average of 11.7 mpg.  I had no idea my mileage could get this low.  Michigan winter driving
How many miles on your truck?
  • 6 months later...
I recently noticed that my truck performance was considerably worse than usual. My truck is 2015 5.3L and has right at 30k miles. I bought the truck new and from the beginning averaged about 16-18 mpg around town. I would get 20-23 mpg on the highway. The last month I've noticed I'm getting about 12-14 mpg around town and only slightly better on the highway.
Interestingly enough, I got a call from my dealer that OnStar/GMC has notified them of "poor performance" on my truck and I need to bring it in.
Well, like many others I'm sure I avoid the dealership at all costs. The whole process is an inconvenience and their prices for everything are ridiculous.
I'm going to check air filter, oil level and tire pressure. I don't have any lights on or notifications from the truck itself, everything appears to be fine.
I'll report back when I find something out, but taking to the dealer as a last resort.
Josh B.
It's not winter gas. It's WINTER period. Here is 100K of fuel records. Tank by tank. Winter gas has 1.5% less BTU content than summer gas meaning winter gas has a maximum impact of 1.5% or 0.3 mpg on a 20 mpg truck. As you can see WINTER has a much more profound effect. Winter meaning COLD. You would have to be driving a vehicle capable of 66.667 mpg to effect a 1 mpg difference in mileage based on the fuels composition between summer and winter.
So basically the majority of swing from summer to winter is 'viscous drag' of cold lubricants.
Grumpy Bear - Good info & I'm sure that may be the case for some folks. In my instance, I'm in Florida (Tampa Bay region) and it's still 90+ degrees out.
Josh B.
  • Haha 1
Josh B.
You do have some seasonal shift, yes? So your swings would be much more muted.
I have this sign at the edge of town where I come in at 45 mpg on cruse control and exactly at that sign hit the cancel button and then observe how far I coast to reach the city limit of 30 mph. There is a hundred yards difference between a 95 F mid day glide down and a 2 AM 65 F repeat. Most of that drag is in the wheel bearing grease in the front hubs. Just an example of viscous drag. Distance is almost half on a 30F winter day. Anyway just given some things to think about and dispense with the idea that 'winter fuel' has anything to do with anything the average guy would ever notice while doing his 'once in awhile' hand calculation checks. :thumbs:
Hey Grumps?  I noticed you did put Amsoil into your Rear Differential @ 100K.  I do believe I lost couple tenths on MPG's when I converted mine over but I did up the capacity by 2qts so maybe that dinged me too?  The gear oil is different grade than OEM but is 100% better imo I am super impressed with AMS gear oils!
:) I used it because....I needed it like yesterday and a local dealer had some on hand. I could not wait for my regular shipment from Hoer as I hit it on a weekend.  Still, I'm not disappointed and it did not seem to have any impact on MPG. Cool! Then again I was already using Red Line 75W90 instead of the OEM 75W85. There is a point were protection is more important to me than fuel efficiency. Did I say that out loud? :crackup:
I bought one more quart than I actually needed. That hurt $$$$$.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
