Can you believe this?
I walked out to my truck yesterday and found that the paint is flaking off the side door molding between the molding and the chrome accent. That is not an area that could get hit with anything to chip it. I bet it would cost me several hundred dollars to have the door touched up. I think they would have to sand down and paint the whole door molding so the paint sticks to it. It is not right for a 7 year old vehicle to have paint flaking off.
Flaking or did you get a good door hit from someone.
That trim can take a fairly good hit without marking up..
The paint not so much.
That molding is curved, and I don't see how any car door could hit the paint in that area. The paint is flaking on the top edge of the molding and there is no mark indicating that it was hit by anything. To me it looks like the plastic wasn't prepped correctly and now the paint is separating from plastic and flaking off.
Good Morning flyboyron,
We are sorry to hear of the paint concern that you are experiencing with your Silverado and we certainly recognize any frustration that may be present. Please allow our team the opportunity to take a look into your situation and see what the next best steps are for you. To do so, please send us a private message that includes your VIN, full contact information, current mileage, and preferred dealership. Thank you and we look forward to working with you.
Philip J.
GM Customer Care
7 year old vehicle and I don't see why your upset over a little chip like that. 7 year old paint is not going to stay perfect through the trucks life you have to expect that and it being door trim with the abuse it takes with heat and cold temps its going to happen. Most likely it got hit with another door and cracked the paint and over time with the weather it chipped, put some touch-up paint on it and be done.
So again its 7 years old exposed to the elements, don't know what the big deal is.
It could have easily happened in a parking lot. Don't have to be a door ding, could be something that someone was loading and accidentally hit the door. I don't see a problem with just using touch up paint, especially with where it's at. Touch it up and forget about it.
I'm gonna have to agree with Silverado4x4 on this one. My truck is only a year and a half old and I have more body issues that that and I baby my vehicle. So much so, I don't even run it through auto car washes. Good luck, but if that's all the body damage you have for 7 years, I think luck is already on your side! [emoji3][emoji6]
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
