Rust on 2014 Silverado?
Does anyone know if the insides of our frames are dipped in wax, too? I was thinking about doing an internal rust coating (the Eastwood one, probably), but I'm not sure if this would cause issues if there is wax inside the frame.
The inside is also wax coated. The Eastwood spray for boxed frames won't do any good unless you borescoped the inside and checked the condition of the wax.
  • Replies 50
On the inside of our frames we will have to see how the wax holds up. I would think it should hold up well considering no direct contact to elements or wheel splash. But then again it depends on how well it is holding its adhesion to frame .
Is it necessary to wire brush/scrape at rust spots before spraying over them? I don't have much rust yet, but I want to stay informed and on top of it.
its not necessary to do jack sh*t to the rust spots unless you're OCD in that case you should've had it treated immediately upon purchase....what CAN happen is moisture getting trapped under the spray coat & causing worse rust.
But yes - if you're going to paint it you should remove surface rust - don't go crazy just get the surface stuff off.
  • 4 weeks later...
After reading this post I went out to check my frame and all I can say is WOW... I had a 98 Silverado that I also treated the frame with just paint and primer that held up decent. I purchased this truck a 2014 a month ago without even thinking of looking below. No biggie I will get after it in the spring and treat it as I did my other truck.
Can you guys post a pic of the spray oil you use I would like to try that rather than paint if it works better.
Well I didn't mean to offend you.
I'm just baffled over how we got such different results.
My wax hasn't "shriveled" or peeled off like you are so adamant will happen. I've applied FF over a dozen times now. Maybe your pro's were using the thinner version because it's easier to spray. Mine is the stuff on the right.
Even though they specifically say 'not to be used as undercoating'? How did you apply it?
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
