2016 High Country SMOKING, Shame on GM Switching to Ford
Here is the oil my catch can caught. The first mark at the bottom of the cup is when I changed the factory oil at 1138 miles. The top mark is at 5751 miles. That's almost a full cup of oil in that amount of miles.
  • Replies 75
I know that I can't prove this but I still question the 4 cylinder deactivation system on these trucks, I had mine tuned and I have 4 friends with Chevy's that had them tuned with the V4 switch disabled and no smoke, no problems at all.
I am sure I am about to get blasted because I have no proof but just feels like GM forced this technology.
I didn't experience any AFM issues with any of my trucks but I have read the horror stories. I originally used the Range AFM disabler, but now I use the Bully Dog to deactivate it. I can't remember the last time I saw V4 show up in my DIC.
My 2016 has 16M miles, never smokes and uses so little oil it's scary. I had a 2014 and it went two years and nearly 30M with no smoking and phenomenal oil life. Parked in my garage and started in the garage. I've even left it running while I ran back in the house to get something, then held my breath to avoid CO2. Whatever is causing the smoke not all are doing it.
And since it happens at irregular intervals that's evidence against the dealers explanation.
That is a lot. Which catch can do you use and do you also have the clean side option that hooks up to the air box? I'm wondering if that's even necessary.
I have the RX Performance catch can. At the time of purchase, there was nothing available for the clean air side, but looking at their website, it appears that now they do. I guess I'll be getting something for the clean side.
If it was over fueled then it would be black smoke. Just like in the old days with carbs and you had the choke on or even a lawn mower, it would bletch out black smoke.
Also not to mention if it was putting that much fuel out, then your oil is trashed with fuel and the cylinders are getting a nice wash down every time you start the truck.
If you can, take it to another dealer. The one you are working with now isn't doing you any favors. That is definitely not normal and no visible smoke should be coming out of the exhaust. That is the main reason for particulate filters being put on diesels, so you can't see anything coming out of the tail pipe.
Not necessarily. Over fueling that results in partially combusted fuel is black. Raw fuel sprayed on something hot can be white...just like condensation.
A catch can will stop it guaranteed, the magical unicorn of a $300 aluminum can and 0.50 cents of hose cures all oil consumption non problems, the massive 100% of owners who have intake valve coking issues and any that smoke enough to set off alarms inside the house. These awesome unproven devices will promise to stop any issue not present and allow you to open your hood at the local starbucks after discussing the KO2's you just put on and leave the other dads in awe at the race inspired underhood ornament.
Stop excessive start up smoke with a catch can :rollin: What can't they do?
Tyler
Tyler
You are joking, right?
I've read two of his replies to threads this morning. Both of them are like this.
Catch Can = Snake Oil
At least on these trucks
That's what I'm trying to find out...hocus pocus or not. I can see with FI applications but not so sure about NA. Although Horacio's picture above shows quite a bit of oil after 2,000 miles. That's about a quart every 8,000 miles and that's just from blow by.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
