There are members who have installed this hood and you may hear some good things. I personally do not like extra scoops and vents as decoration. The manufacturer claims these replacement hoods have some functionality but our trucks with their massive grills are not struggling for air. Paint, wrap, or stripes on the hood make more sense, imo.
I like the 16/17 hoods. I personally don't like the Rk sport hoods. Look ricey to me on a truck. Just my .02 though.
If you're going for the style thats one thing. Personally fiberglass anything scares me unless you add additional support to it. I know there was a user on the forums that added that hood (or very similar) to his 15 silverado and linexed everything. Thing looked bad ass. I think it would probably be better with linex as that would make it stronger.
I also worry about the fit/finish. I remember civic and 240sx guys back in the day that bought wide body and bumpers and they never fit right. Perhaps its a quality thing or whatever but it's a memory thats seated in my head and scares me. Last thing you want is a new hood/fender that isn't aligned on a 50k+ truck.
RK sport maxes good products. I remember seeing a Mallet Solstice at Sema one year that had a full kit from them plus a custom hard top they made and it looked amazing. There is a good looking cowl hood out there too that isn't fiberglass, can't remember who makes it.
Edited by Darth_Vader
... Like this? haha, just got this done last week. Tailgate matches too.
I personally do not like glass hoods and would never want those scoops either!
RT
I am with you on this. I like my aluminum hood and don't want any extra unnecessary weight.
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
I had the rks sport hood for my 13 Sierra. Fit like shit and I work at a body shop as a painter. They are all bowed in the middle and it's bad enough that it's impossible to get them to look great. It will just be "good enough"
I'm thinking about the 17 hd hood on mine... and yes I know it's not a direct swap... but the 17 hd hood looks good
If you don't wanna replace the hood and don't care about functionality, Air Design USA makes a kit for Silverados and Sierras that includes a hood "scoop" lol. It's something unique I saw at SEMA last year
Sent from my iPhone using Tapatalk58b19894e57ca0a39c20d4c79b2e49ab.jpge89efe32f9afae98336919969c18a613.jpg
Edited by Abearclaw
I don't mind the look of it, but I'd want something functional too. If I'm going to do that, I mine as well put NOS stickers on my truck haha
    LCH14
    LCH14
  • Who's Online   1 Member, 0 Anonymous, 1,589 Guests (See full list)
    • The 92-95 SCPI spider injectors are notoriously problematic and hard to source new replacements. I’d pull the intake manifold first to inspect cracked lines and brittle plastic legs before dropping $350 on a rebuild. The 1.5 OBD system only offers limited data, no misfire tracking, which is normal for this 1995 model. Enjoy the project!
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
