Front bumper air dam
I'm offroad quite a bit at our woodlot & chances are it would get damaged.
  • Replies 93
You know you don't have to remove the grill and bumper right??? Lol
Looks better
I have never had a problem with the air dam on my 2500, using it off road on the property. I go over a lot of cropland terraces, thru washouts, etc and haven't beaten it up. And my front is not lifted. Just lowered the back with a set of McGaughy's shackles. I even have a Curt front receiver hitch on the pickup that meets up at the bottom of the air dam and it is not an issue. Have a cover on it, and it has dug into some ground occasionally, but nothing to cause concern. I suppose if one is doing some Baja stuff or the Rubicon it might be an issue to leave the air dam on.
I have to concede that a pickup does look a little better without the air dam. Since they changed the style of air dam from the one I took off my 2013 1500 and the one that is on my 2015 2500, the latter one if I took it off would look a little goofy. I could see trimming the bottom of the air dam I suppose. About the only way I think my 2500 would look right is if I just yanked the entire bumper off and put on a major bumper / grill guard up grade like one of the Herd, Ali-Arc, or Dakota Hills bumper and grill guard combinations. Which one of those is in my future!
Like this.....
Like this.....
I spoke with Dakota Hills. $2500 shipped for what I want. Low on the priority list but will buy eventually. Is Herd and Ali-Arc aluminum too? That's the major selling point of the Dakota Hills. And they look boss as hell
Yes, both Herd and Ali-Arc are both aluminum also. Any of these three would be as good as it gets for serious front end protection. This says it all.....
That was a Dakota Hills version.
Herd bumpers here:
http://herd.com/bumpers/pickups/
Ali-Arc here:
http://www.aliarc.com/products/details/?sect=pickups_1&brand_id=9
Shop all of them and get them to compete for your dollars!!!!!
I have a different brand on my semi truck, but similar, and I sent Bambi airborne a couple of nights ago in Nebraska. All I had was hair on the bumper. Not a bit of damage. But Bambi sure went for a ride. Not sure if was killed, but sure in a world of hurt.
Thanks for reminding me of all of this. Hadn't thought of one for the pickup in a while. Now going to have to see about rectifying that. Especially since I can write it off as a business expense!
Not sure what the shipping costs would be, but w/ the Cdn dollar being in the toilet (1 = .73US$), the Ali-Arc might save you some money.
Not sure if they make pick up bumpers, but they do make racks & tool boxes:
http://www.mikmak.net/
I was thinking of trimming the lower 'flange' of the air dam. But seeing how the bracing is attached, I gave up on that, pretty much @ the same time I found out about the BOSS trim insert.
Herd bumpers here:
Ali-Arc here:
Mmmmm! That ad makes me feel like having fresh burgers for dinner! :)
These bumpers look extremely heavy duty but I would question how well the frame would hold up in a collision with five cows. At 2000lbs each they should practically stop the truck dead. The engine may not be damaged but wouldn't the frame be twisted so that an accurate alignment would be next to impossible to acheive? The truck certianly never be the same. They do look awesome though!
I'm worried more about deer!
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
